Hello guys!
I’m using webmin and virtualmin to configure my mail server. And for that I get up my postfix, dovecot and saslauthd services.
But when I sent an test mail from my Gmail to my server, I get this error:
fatal: no SASL authentication mechanisms
Here is all my configuration files and log files, to help us:
Nov 4 14:42:49 ns1 postfix/postfix-script[2147]: stopping the Postfix mail system
Nov 4 14:42:49 ns1 postfix/master[1340]: terminating on signal 15
Nov 4 14:42:49 ns1 postfix/postfix-script[2228]: starting the Postfix mail system
Nov 4 14:42:49 ns1 postfix/master[2230]: daemon started – version 2.10.1, configuration /etc/postfix
Nov 4 14:45:37 ns1 postfix/smtpd[2314]: connect from mail-oi0-f51.google.com[209.85.218.51]
Nov 4 14:45:37 ns1 postfix/smtpd[2314]: fatal: no SASL authentication mechanisms
Nov 4 14:45:38 ns1 postfix/master[2230]: warning: process /usr/libexec/postfix/smtpd pid 2314 exit status 1
Nov 4 14:45:38 ns1 postfix/master[2230]: warning: /usr/libexec/postfix/smtpd: bad command startup – throttling
Nov 4 14:47:18 ns1 postfix/anvil[2317]: statistics: max connection rate 1/60s for (smtp:209.85.218.51) at Nov 4 14:45:37
Nov 4 14:47:18 ns1 postfix/anvil[2317]: statistics: max connection count 1 for (smtp:209.85.218.51) at Nov 4 14:45:37
Nov 4 14:47:18 ns1 postfix/anvil[2317]: statistics: max cache size 1 at Nov 4 14:45:37
/var/log/maillog
Nov 04 14:45:37 auth: Debug: Loading modules from directory: /usr/lib64/dovecot/auth
Nov 04 14:45:37 auth: Debug: Module loaded: /usr/lib64/dovecot/auth/libdriver_sqlite.so
Nov 04 14:45:37 auth: Debug: Read auth token secret from /var/run/dovecot/auth-token-secret.dat
Nov 04 14:45:37 auth: Debug: auth client connected (pid=0)
/var/log/dovecot.debug
Nov 04 14:43:28 anvil: Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
Nov 04 14:43:28 log: Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
Nov 04 14:43:28 master: Warning: Killed with signal 15 (by pid=1 uid=0 code=kill)
Nov 04 14:43:28 master: Info: Dovecot v2.2.10 starting up for imap, pop3 (core dumps disabled)
/var/log/dovecot.info
Proccess killed because I restarted the service, so ignore that, please.
[root@ns1 ~]# systemctl status dovecot -l
dovecot.service - Dovecot IMAP/POP3 email server
Loaded: loaded (/usr/lib/systemd/system/dovecot.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2016-11-04 14:43:28 BRST; 35s ago
Process: 2246 ExecStartPre=/usr/libexec/dovecot/prestartscript (code=exited, status=0/SUCCESS)
Main PID: 2250 (dovecot)
CGroup: /system.slice/dovecot.service
├─2250 /usr/sbin/dovecot -F
├─2251 dovecot/anvil
├─2252 dovecot/log
└─2254 dovecot/config
Nov 04 14:43:28 ns1.domain.com.br systemd[1]: Starting Dovecot IMAP/POP3 email server…
Nov 04 14:43:28 ns1.domain.com.br systemd[1]: Started Dovecot IMAP/POP3 email server.
[root@ns1 ~]# systemctl status postfix -l
postfix.service - Postfix Mail Transport Agent
Loaded: loaded (/usr/lib/systemd/system/postfix.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2016-11-04 14:42:49 BRST; 1min 55s ago
Process: 2141 ExecStop=/usr/sbin/postfix stop (code=exited, status=0/SUCCESS)
Process: 2158 ExecStart=/usr/sbin/postfix start (code=exited, status=0/SUCCESS)
Process: 2154 ExecStartPre=/usr/libexec/postfix/chroot-update (code=exited, status=0/SUCCESS)
Process: 2152 ExecStartPre=/usr/libexec/postfix/aliasesdb (code=exited, status=0/SUCCESS)
Main PID: 2230 (master)
CGroup: /system.slice/postfix.service
├─2230 /usr/libexec/postfix/master -w
├─2231 pickup -l -t unix -u
└─2232 qmgr -l -t unix -u
Nov 04 14:42:49 ns1.domain.com.br systemd[1]: Starting Postfix Mail Transport Agent…
Nov 04 14:42:49 ns1.domain.com.br postfix/postfix-script[2228]: starting the Postfix mail system
Nov 04 14:42:49 ns1.domain.com.br postfix/master[2230]: daemon started – version 2.10.1, configuration /etc/postfix
Nov 04 14:42:49 ns1.domain.com.br systemd[1]: Started Postfix Mail Transport Agent.
[root@ns1 ~]# systemctl status saslauthd -l
saslauthd.service - SASL authentication daemon.
Loaded: loaded (/usr/lib/systemd/system/saslauthd.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2016-11-03 12:19:08 BRST; 1 day 2h ago
Process: 1978 ExecStart=/usr/sbin/saslauthd -m $SOCKETDIR -a $MECH $FLAGS (code=exited, status=0/SUCCESS)
Main PID: 1979 (saslauthd)
CGroup: /system.slice/saslauthd.service
├─1979 /usr/sbin/saslauthd -m /run/saslauthd -a pam -r
├─1980 /usr/sbin/saslauthd -m /run/saslauthd -a pam -r
├─1981 /usr/sbin/saslauthd -m /run/saslauthd -a pam -r
├─1982 /usr/sbin/saslauthd -m /run/saslauthd -a pam -r
└─1983 /usr/sbin/saslauthd -m /run/saslauthd -a pam -r
Nov 03 12:19:08 ns1.domain.com.br systemd[1]: Starting SASL authentication daemon…
Nov 03 12:19:08 ns1.domain.com.br saslauthd[1979]: detach_tty : master pid is: 1979
Nov 03 12:19:08 ns1.domain.com.br saslauthd[1979]: ipc_init : listening on socket: /run/saslauthd/mux
Nov 03 12:19:08 ns1.domain.com.br systemd[1]: Started SASL authentication daemon…
# MY CONFIGS
myhostname = mail.domain.com.br
mydomain = domain.com.br
myorigin = $mydomain
inet_protocols = ipv4
mydestination = $myhostname, localhost, ns1.domain.com.br
mynetworks = 168.100.189.0/28, 127.0.0.0/8
relay_domains = $mydestination
home_mailbox = Maildir/
recipient_bcc_maps = hash:/etc/postfix/bcc
queue_directory = /var/spool/postfix
SASL
smtpd_sasl_type = dovecot
smtpd_sasl_path = private/auth
smtpd_sasl_auth_enable = yes
smtpd_relay_restrictions = permit_mynetworks,permit_sasl_authenticated,reject_unauth_destination
smtpd_sasl_security_options = noanonymous noplaintext
smtpd_sasl_local_domain = domain.com.br
smtpd_recipient_restrictions = check_policy_service unix:/var/spool/postfix/postgrey/socket
TLS
smtpd_use_tls = yes
smtpd_tls_key_file = /etc/postfix/ssl/mail.domain.com.br.key
smtpd_tls_cert_file = /etc/postfix/ssl/mail.domain.com.br.crt
smtpd_tls_security_level=encrypt
smtpd_tls_auth_only = yes
smtpd_sasl_tls_security_options = noanonymous, noplaintext
OTHERS
milter_default_action = accept
milter_protocol = 2
smtpd_milters = inet:localhost:8891
non_smtpd_milters = inet:localhost:8891
/etc/postfix/main.cf
smtp inet n - n - - smtpd
/etc/postfix/master.cf
protocols = imap pop3
listen = *
/etc/dovecot/dovecot.conf
disable_plaintext_auth = no
auth_mechanisms = plain login
/etc/dovecot/10-auth.conf
service auth {
unix_listener auth-userdb {
#mode = 0660
#user = postfix
#group = postfix
Postfix smtp-auth
unix_listener /var/spool/postfix/private/auth {
mode = 0666
user = postfix
group = postfix
Auth process is run as this user.
#user = $default_internal_user
/etc/dovecot/10-master.conf
log_path = /var/log/dovecot.info
info_log_path = /var/log/dovecot.info
debug_log_path = /var/log/dovecot.debug
auth_verbose = yes
auth_debug = yes
mail_debug = yes
verbose_ssl = yes
/etc/dovecot/10-logging.conf
Thanks for the atention.
