I have a fresh new CentOS 7.1 with Virtualmin installed and configured.
I am trying to configure Postfix but I have problems with gmail and some others server.
I have these errors :
- connect to io-118.arrakis.es[212.59.201.118]:25: Connection timed out
- connect to club-internet.com[69.172.201.208]:25: Connection timed out
- host mx1.free.fr[212.27.48.6] said: 451 too many errors from your ip
- connect to unibeton.com[208.91.197.128]:25: Connection timed out
- lost connection with web.dennyspage.com[46.17.100.214] while receiving the initial server greeting
- For gMail, I have the error : mail transport unavailable
Here is a postconf -n report :
[root@serveur ~]# postconf -n
postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_sender_restrictions
postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_client_restrictions
postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_helo_restrictions
allow_percent_hack = no
command_directory = /usr/sbin
config_directory = /etc/postfix
daemon_directory = /usr/libexec/postfix
data_directory = /var/lib/postfix
debug_peer_level = 2
debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin ddd $daemon_directory/$process_name $process_id & sleep 5
default_destination_concurrency_limit = 10
home_mailbox = Maildir/
html_directory = no
inet_protocols = all
mailbox_size_limit = 0
mailq_path = /usr/bin/mailq.postfix
manpage_directory = /usr/share/man
mydestination = $myhostname, localhost.$mydomain, localhost, serveur.mondomaine.fr
mydomain = mondomaine.fr
myhostname = serveur.mondomaine.fr
newaliases_path = /usr/bin/newaliases.postfix
readme_directory = /usr/share/doc/postfix-2.10.1/README_FILES
sample_directory = /usr/share/doc/postfix-2.10.1/samples
sendmail_path = /usr/sbin/sendmail.postfix
setgid_group = postdrop
slow_destination_concurrency_limit = 2
slow_destination_rate_delay = 1s
slow_destination_recipient_limit = 2
slow_initial_destination_concurrency = 1
smtpd_sasl_auth_enable = yes
smtpd_tls_cert_file = /etc/postfix/postfix.cert.pem
smtpd_tls_key_file = /etc/postfix/postfix.key.pem
smtpd_tls_mandatory_ciphers = high
smtpd_tls_mandatory_protocols = SSLv3, TLSv1
smtpd_use_tls = yes
transport_maps = hash:/etc/postfix/transport, regexp:/etc/postfix/transport_regexp
unknown_local_recipient_reject_code = 550
This is my master.cf :
[code]smtp inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes
#smtp inet n - n - 1 postscreen
#smtpd pass - - n - - smtpd
#dnsblog unix - - n - 0 dnsblog
#tlsproxy unix - - n - 0 tlsproxy
#submission inet n - n - - smtpd
-o syslog_name=postfix/submission
-o smtpd_tls_security_level=
-o smtpd_reject_unlisted_recipient=no
-o smtpd_client_restrictions=$mua_client_restrictions
-o smtpd_helo_restrictions=$mua_helo_restrictions
-o smtpd_sender_restrictions=$mua_sender_restrictions
-o smtpd_recipient_restrictions=permit_sasl_authenticated,reject
-o milter_macro_daemon_name=ORIGINATING
smtps inet n - n - - smtpd -o syslog_name=postfix/smtps -o smtpd_tls_wrappermode=yes -o smtpd_sasl_auth_enable=yes -o smtpd_reject_unlisted_recipient=no -o smtpd_client_restrictions=$mua_client_restrictions -o smtpd_helo_restrictions=$mua_helo_restrictions -o smtpd_sender_restrictions=$mua_sender_restrictions -o smtpd_recipient_restrictions=permit_sasl_authenticated,reject -o milter_macro_daemon_name=ORIGINATING
#628 inet n - n - - qmqpd
pickup unix n - n 60 1 pickup
cleanup unix n - n - 0 cleanup
qmgr unix n - n 300 1 qmgr
#qmgr unix n - n 300 1 oqmgr
tlsmgr unix - - n 1000? 1 tlsmgr
rewrite unix - - n - - trivial-rewrite
bounce unix - - n - 0 bounce
defer unix - - n - 0 bounce
trace unix - - n - 0 bounce
verify unix - - n - 1 verify
flush unix n - n 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - n - - smtp
relay unix - - n - - smtp
-o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - n - - showq
error unix - - n - - error
retry unix - - n - - error
discard unix - - n - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - n - - lmtp
anvil unix - - n - 1 anvil
scache unix - - n - 1 scache
Interfaces to non-Postfix software. Be sure to examine the manual
pages of the non-Postfix software to find out what options it wants.
Many of the following services use the Postfix pipe(8) delivery
agent. See the pipe(8) man page for information about ${recipient}
and other message envelope options.
maildrop. See the Postfix MAILDROP_README file for details.
Also specify in main.cf: maildrop_destination_recipient_limit=1
#maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient}
Recent Cyrus versions can use the existing “lmtp” master.cf entry.
Specify in cyrus.conf:
lmtp cmd=“lmtpd -a” listen=“localhost:lmtp” proto=tcp4
Specify in main.cf one or more of the following:
mailbox_transport = lmtp:inet:localhost
virtual_transport = lmtp:inet:localhost
Cyrus 2.1.5 (Amos Gouaux)
Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -r ${sender} -m ${extension} ${user}
Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
flags=R user=cyrus argv=/usr/lib/cyrus-imapd/deliver -e -m ${extension} ${user}
See the Postfix UUCP_README file for configuration details.
#uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
Other external delivery methods.
#ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
#bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/local/sbin/bsmtp -f $sender $nexthop $recipient
#scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store
${nexthop} ${user} ${extension}
#mailman unix - n n - - pipe
flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
${nexthop} ${user}
submission inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes
Slow - config
slow unix - - n - 5 smtp
-o syslog_name=postfix-slow
-o smtp_destination_concurrency_limit=3
-o slow_destination_rate_delay=1
[/code]
And finally my transport :
wanadoo.com slow:
wanadoo.fr slow:
orange.com slow:
orange.fr slow:
#yahoo.fr slow:
free.fr slow:
aliceadsl.fr slow:
alicepro.fr slow:
aliceteam.fr slow:
libertysurf.fr slow:
libertysurf.net slow:
worldonline.fr slow:
freesbee.fr slow:
infonie.fr slow:
monsieurcinema.com slow:
teamtiscali.com slow:
nomade.fr slow:
chez.com slow:
nordnet.fr slow:
hotmail.com slow:
yopmail.com slow:
laposte.net slow:
alice.fr slow:
ymail.com slow:
rocketmail.com slow:
gmail.com slow:
yahoo.fr slow:
I am very annoyed, so any help will be appreciated :roll:
Thank you
