| SYSTEM INFORMATION | |
| OS type and version | Ubuntu Linux 22.04.2 REQUIRED |
| Virtualmin version | 7.7 Pro REQUIRED |
| postfix version 3.6.4 |
I have this problem with a certain email which is not getting to my users mailbox. It seems that most of the mail if not all of it is delivered properly. This is the only email that I am aware is not getting where it supposed to. It happens to be from a bank–it is a link to a docusign document. I had the same behavior for two email users in my system. The email was delivered sucessfully to another system that I have an email account to–microsoft outlook.
I have looked at the mail logs and I cannot make any sense out of it except that the email that was not delivered did not have the sections SPAMD in it but skipped that. The email that was delivered had the spamd section in it. I see no error message that I understand. Hopefully someone who knows more about Postfix can steer me in the right direction. Below find the relevant mail log sections showing email that was not delivered and email that was delivered.
Any help would be appreciated. Thanks
Michael
Log:
Mail log:
Unsucessful messages:
15:09:10 mrxxxxtl postfix/qmgr[423532]: CECB92341FEF: removed
15:09:10 mrxxxxtl postfix/local[1887976]: CECB92341 FEF: to=<“rozzzze@rxxxxt.com”@mrxxxxt1.com>, orig_to=rozzzze@rxxxxt.com, relay=local, delay=2, delays=1.8/0/0/0.2, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $D0MAIN -d $L0GNAME)
15:09:10 mrxxxxtl postfix/smtpd[1885215]: disconnect from mxdalpx06.wellsfargo.com[159.45.87.82] ehlo=2 starttls=1 mail=1 rcpt=1 data=1 quit=1 commands=7
15:09:10 mrxxxxtl postfix/trivial-rewrite[1887937]: warning: do not list domain mrxxxxt1.com in BOTH mydestination and virtual_alias_domains
15:09:10 mrxxxxtl postfix/qmgr[423532]: CECB92341FEF: from=alerts@notify.wellsfargo.com, size=7058, nrcpt=1 (queue active)
15:09:10 mrxxxxtl opendkim[414077]: CECB92341FEF: s=2011-05-wfb d=notify.wellsfargo.com a=rsa-sha256 SSL
15:09:10 mrxxxxtl opendkim[414077]: CECB92341FEF: DKIM verification successful
15:09:08 mrxxxxtl postfix/cleanup[1887938]: CECB92341FEF: message-id=1065534975.9753805.1689102547680@mn2-162a-ixb-al.wellsfargo.com
15:09:08 mrxxxxtl postfix/smtpd[1885215]: CECB92341FEF: client=mxdalpx06.wellsfargo.com[159.45.87.82]
15:09:08 mrxxxxtl postfix/smtpd[1885215]: connect from mxdalpx06.wellsfargo.com[159.45.87.82]
06:21:55 mrxxxxtl postfix/qmgr[423532]: 3CFBF2342001: removed
06:21:55 mrxxxxtl postfix/localf1994919]: 3CFBF2342001: to=<“rozzzze@rxxxxt.com”@mrxxxxt1.com>, orig_to=rrxxxxt@rxxxxt.net, relay=local, delay=2.8, delays=2.6/0/0/0.21, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $D0MAIN -d $L0GNAME)
06:21:55 mrxxxxtl postfix/smtpd[1994903]: disconnect from mta2.mail1.wf.com[13.111.189.30] ehlo=2 starttls=1 mail=1 rcpt=1 data=1 quit=1 commands=7
06:21:55 mrxxxxtl postfix/trivial-rewrite[1994110]: warning: do not list domain mrxxxxt1.com in BOTH mydestination and virtual_alias_domains
06:21:55 mrxxxxtl postfix/qmgr[423532]: 3CFBF2342001: from=bounce-28_HTML-54464560-197392-518005185-78409@bounce.maill.wellsfargo.com, size=47322, nrcpt=1 (queue active)
06:21:55 mrxxxxtl opendkim[414077]: 3CFBF2342001: s=200608 d=mail1.wellsfargo.com a=rsa-sha256 SSL
06:21:55 mrxxxxtl opendkim[414077]: 3CFBF2342001: DKIM verification successful
06:21:53 mrxxxxtl postfix/cleanup[1994917]: 3CFBF2342001: message-id=2e5e15c4-3768-4703-b262-54fcd9ae517e@atl1s07mta3200.xt.local
06:21:53 mrxxxxtl postfix/smtpd[1994903]: 3CFBF2342001: client=mta2.maill.wf.com[13.111.189.30]
06:21:52 mrxxxxtl postfix/smtpd[1994903]: connect from mta2.maill.wf.com[13.111.189.30]
Sucessful Messages:
16:01:40 mrxxxxtl postfix/qmgr[423532]: ABA8C2341FFB: removed
16:01:40 mrxxxxtl postfix/local[1711210]: ABA8C2341FFB: to=<“rozzzze@rxxxxt.com”@mrxxxxt1.com>, orig_to=rozzzze@rxxxxt.C0M, relay=local, delay=2.7, delays=2/0/0/0.73, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $D0MAIN -d $L0GNAME)
16:01:40 mrxxxxtl spamd[1659938]: spamd: result: . -15 - DKIMWL_WL_HIGH, DKIM_SIGNED,DKIM_VALID,DKIM_VALID_AU,ENV_AND_HDR_SPF_MATCH,HTML_MESSAGE,MIME_HTML_ONLY,SPF_HEL0_N0NE,SPF_PASS,TRACKER_ID,T_REMOTE_IMAGE,T_SCC_BODY_TEXT_LINE,URIBL_BLOCKED,USER_IN_DEF_DKIM_WL,USER_IN_DEF_SPF_WL scantime=0.6,size=6436,user=rozzzze@rxxxxt.com,uid=1008,required_score=5.0,rhost=::1,raddr=::1,rport=38514,mid=790020297.8574833.1689019297052@mn2-125a-ixb-al.wellsfargo.com,autolearn=no autolearn_force=no
16:01:40 mrxxxxtl spamd[1659938]: spamd: clean message (-15.4/5.0) for rozzzze@rxxxxt.com:1008 in 0.6 seconds, 6436 bytes.
16:01:39 mrxxxxtl spamd[1659938]: spamd: processing message 790020297.8574833.1689019297052@mn2-125a-ixb-al.wellsfargo.com for rozzzze@rxxxxt.com :1008
16:01:39 mrxxxxtl spamd[1659938]: spamd: setuid to rozzzze@rxxxxt.com succeeded
16:01:39 mrxxxxtl spamd[1659938]: spamd: connection from ::1 [: :1]:38514 to port 783, fd 5
16:01:39 mrxxxxtl postfix/smtpd[1712909]: disconnect from mxdalpv07.wellsfargo.com[159.45.16.112] ehlo=2 starttls=1 mail=1 rcpt=1 data=1 quit=1 commands=7
16:01:39 mrxxxxtl postfix/trivial-rewrite[1711167]: warning: do not list domain mrxxxxt1.com in BOTH mydestination and virtual_alias_domains
16:01:39 mrxxxxtl postfix/qmgr[423532]: ABA8C2341FFB: from=alerts@notify.wellsfargo.com, size=6177, nrcpt=1 (queue active)
16:01:39 mrxxxxtl opendkim[414077]: ABA8C2341FFB: s=2011-05-wfb d=notify.wellsfargo.com a=rsa-sha256 SSL
16:01:39 mrxxxxtl opendkim[414077]: ABA8C2341FFB: DKIM verification successful
16:01:37 mrxxxxtl postfix/cleanup[1711168]: ABA8C2341 FFB: message-id=790020297.8574833.1689019297052@mn2-125a-ixb-al.wellsfargo.com
16:01:37 mrxxxxtl postfix/smtpd[1712909]: ABA8C2341FFB: client=mxdalpv07.wellsfargo.com[159.45.16.112]
16:01:37 mrxxxxtl postfix/smtpd[1712909]: connect from mxdalpv07.wellsfargo.com[159.45.16.112]
6:48:10 mrxxxxtl postfix/qmgr[423532]: AE4622340FFB: removed
16:48:10 mrxxxxtl postfix/local[1913508]: AE4622340FFB: to=<“rozzzze@rxxxxt.com”@mrxxxxt1.com>, orig_to=rrxxxxt@rxxxxt.net, relay=local, delay=0.84, delays=0.24/0/0/0.6, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $D0MAIN -d $L0GNAME)
16:48:10 mrxxxxtl spamdf1814388]: spamd: result: . 0 - DKIM_SIGNED,DKIM_VALID,DKIM_VALID_AU,DKIM_VALID_EF,HTML_FONT_LOW_CONTRAST,HTML_MESSAGE,MIME_HTML_ONLY,RCVD_IN_DNSWL_BLOCKED,SPF_HEL0_N0NE, SPF_PASS, T_SCC_BODY_TEXT_LINE, URIBL_BLOCKED scantime=0.4,size=81801,user=rozzzze@rxxxxt.com,uid=1008,required_score=5.0,rhost=::1,raddr=::1,rport=33006,mid=<f9f50bfa-ad94-424a-9e9e-07587a09cdcd@ind1 S01mta61 5.xt.local>, autolearn=ham autolearn_force=no
16:48:10 mrxxxxtl spamd[1814388]: spamd: clean message (-0.1/5.0) for rozzzze@rxxxxt.com:1008 in 0.4 seconds, 81801 bytes.
16:48:10 mrxxxxtl spamd[1814388]: spamd: processing message f9f50bfa-ad94-424a-9e9e-07587a09cdcd@ind1s01mta615.xt.local for rozzzze@rxxxxt.com:1008
16:48:10 mrxxxxtl spamd[1814388]: spamd: setuid to rozzzze@rxxxxt.com succeeded
16:48:10 mrxxxxtl spamd[1814388]: spamd: connection from ::1 [: :1]:33006 to port 783, fd 5
16:48:09 mrxxxxtl postfix/smtpd[1913484]: disconnect from mta2.belkemail.com[207.67.38.193] ehlo=2 starttls=1 mail=1 rcpt=1 data=1 quit=1 commands=7
16:48:09 mrxxxxtl postfix/trivial-rewrite[1913493]: warning: do not list domain mrxxxxt1.com in BOTH mydestination and virtual_alias_domains
16:48:09 mrxxxxtl postfix/qmgr[423532]: AE4622340FFB: from=bounce-39604976_HTML-872007314-81019673-10972016-19746@bounce.belkemail.com, size=82639, nrcpt=1 (queue active)
16:48:09 mrxxxxtl opendkim[414077]: AE4622340FFB: s=200608 d=belkemail.com a=rsa-sha256 SSL
16:48:09 mrxxxxtl opendkim[414077]: AE4622340FFB: DKIM verification successful
16:48:09 mrxxxxtl postfix/cleanup[1913506]: AE4622340FFB: message-id=f9f50bfa-ad94-424a-9e9e-07587a09cdcd@ind1s01mta615.xt.local
16:48:09 mrxxxxtl postfix/smtpd[1913484]: AE4622340FFB: client=mta2.belkemail.com[207.67.38.193]
16:48:09 mrxxxxtl postfix/smtpd[1913484]: connect from mta2.belkemail.com[207.67.38.193]
