I’m not able to receive mail to a valid recipient. The log entries from /var/logs/maillog are below. I remember that when I first set this up I had an error about no canonical maps and set it to ‘hash:/etc/postfix/virtual’ for address mapping, recipient name and sender name lookups.
How can I correct whatever is wrong?
thanks,
tony
[code:1]
Nov 17 13:09:23 linux1 dovecot: imap-login: Login: user=<ezms>, method=PLAIN, rip=::ffff:127.0.0.1, lip=::ffff:127.0.0.1, secured
Nov 17 13:09:23 linux1 dovecot: IMAP(ezms): Disconnected: Logged out
Nov 17 13:10:01 linux1 postfix/smtpd[29485]: connect from sterling-imail2.sterlink.net[199.108.225.98]
Nov 17 13:10:01 linux1 postfix/smtpd[29485]: 46F9E2C600F3: client=sterling-imail2.sterlink.net[199.108.225.98]
Nov 17 13:10:01 linux1 postfix/cleanup[29489]: warning: 46F9E2C600F3: unreasonable recipient_canonical_maps map nesting for ezms@ez-ms.com
Nov 17 13:10:01 linux1 postfix/cleanup[29489]: warning: 46F9E2C600F3: unreasonable canonical_maps map nesting for ezms@ez-ms.com
Nov 17 13:10:01 linux1 postfix/cleanup[29489]: warning: 46F9E2C600F3: unreasonable virtual_alias_maps map nesting for ezms@ez-ms.com
Nov 17 13:10:01 linux1 postfix/cleanup[29489]: 46F9E2C600F3: message-id=<200811171308114.SM02332@truth>
Nov 17 13:10:01 linux1 postfix/qmgr[2341]: 46F9E2C600F3: from=<tonyb@1sit.com>, size=2207, nrcpt=1 (queue active)
Nov 17 13:10:01 linux1 postfix/smtpd[29485]: disconnect from sterling-imail2.sterlink.net[199.108.225.98]
[/code:1]<br><br>Post edited by: tbirnseth, at: 2008/11/20 07:49
Okay, so it looks like ezms is your login name – then as you said, it looks like there might be a loop in the virtual file. The following line may be the culprit:
In Virtualmin, click Webmin -> Servers -> Postfix Mail Server -> Virtual Domains – then look for the section with "ezms" maps to "ezms@ez-ms.com" and delete it.
Make sure to save/apply the changes, and then try sending another message to that account.
That seems to have fixed the delivery issue! Thanks so much!
However, in looking at the maillog, it appears that spamd is not talking to postfix.
[code:1]
Nov 18 00:01:04 linux1 postfix/anvil[13257]: statistics: max cache size 1 at Nov 17 23:57:40
Nov 18 01:15:53 linux1 postfix/postfix-script[15283]: refreshing the Postfix mail system
Nov 18 01:15:53 linux1 postfix/master[3981]: reload configuration /etc/postfix
Nov 18 01:16:07 linux1 postfix/postfix-script[15445]: refreshing the Postfix mail system
Nov 18 01:16:07 linux1 postfix/master[3981]: reload configuration /etc/postfix
Nov 18 01:16:57 linux1 postfix/smtpd[15507]: connect from sterling-imail2.sterlink.net[199.108.225.98]
Nov 18 01:16:57 linux1 postfix/smtpd[15507]: 34DCD2C600F3: client=sterling-imail2.sterlink.net[199.108.225.98]
Nov 18 01:16:57 linux1 postfix/cleanup[15511]: 34DCD2C600F3: message-id=<200811180114713.SM02344@truth>
Nov 18 01:16:57 linux1 postfix/qmgr[15449]: 34DCD2C600F3: from=<tonyb@1sit.com>, size=2156, nrcpt=1 (queue active)
Nov 18 01:16:57 linux1 postfix/smtpd[15507]: disconnect from sterling-imail2.sterlink.net[199.108.225.98]
Nov 18 01:17:00 linux1 spamc[15526]: connect to spamd on 127.0.0.1 failed, retrying (#1 of 3): Connection refused
Nov 18 01:17:01 linux1 spamc[15526]: connect to spamd on 127.0.0.1 failed, retrying (#2 of 3): Connection refused
Nov 18 01:17:02 linux1 spamc[15526]: connect to spamd on 127.0.0.1 failed, retrying (#3 of 3): Connection refused
Nov 18 01:17:03 linux1 spamc[15526]: connection attempt to spamd aborted after 3 retries
Nov 18 01:17:03 linux1 postfix/local[15512]: 34DCD2C600F3: to=<ezms@linux1.ez-merchant-hosting.com>, orig_to=<ezms@ez-ms.com>, relay=local, delay=6.4, delays=0.25/0.06/0/6.1, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail-wrapper -o -a $DOMAIN -d $LOGNAME)
Nov 18 01:17:03 linux1 postfix/qmgr[15449]: 34DCD2C600F3: removed
[/code:1]
That seemed to do it. So I guess the question is why wasn’t it running? Does VM restart it or anything during creation of a new server? I note in the log file that when it started up and got email for this domain that it created a preferences file for the user.
Shouldn’t VM ensure that it’s running as part of server creation?
I can’t really speak to why it wasn’t running a moment ago – but what I’d do is just verify that it’s setup to launch upon system bootup.
To do that, log into Virtualmin, then click Webmin -> System -> Bootup and Shutdown, and make sure Spamassassin’s “At boot” flag is set to “yes”.
Okay, the spamd/spamassassin daemons were not set to start at boot time. I’d assume that webmin’s default is to start them and I don’t recall ever going to that page before. So I have no idea how/why they got turned off.
