I see others have had the problem of Posfix sending outbound email due to port 25 being blocked by their ISP (as in my case).
My Virtualmin server is located on a network with a firewall in the router.
Currently I am able to connect to posfix from a remote IP, i.e.
telnet mail.example-domain.com 26
Trying xx.xxx.xxx.xxx…
Connected to mail.example-domain.com (xx.xxx.xxx.xxx).
Escape character is ‘^]’.
220 amazing.billyfire.net ESMTP Postfix
I am also able to send e-mail from Thunderbird and it ends up in a queue on the server.
var/log/maillog shows comments like:
Dec 31 11:50:43 billyfire postfix/smtp[12193]: connect to mx.west.cox.net[68.6.19.3]: No route to host (port 25)
So my conclusion is that the Postfix is not able to form a connection to the receiving server because it is trying to do so on port 25, which is blocked.
I did some research and a couple of sites: (http://www.go2linux.org/iptables-port-26-redirection-accept-email-on-another-port
and
http://rimuhosting.com/support/settingupemail.jsp?mta=postfix&t=blockingisp#blockingisp)
suggest adding the following rules to the IP table:
#Accept connections on ports 25, 26 and 110
iptables -A INPUT -p tcp --dport 25 -j ACCEPT
iptables -A INPUT -p tcp --dport 110 -j ACCEPT
iptables -A INPUT -p tcp --dport 26 -j ACCEPT
##Next redirect 26 to 25
iptables -A PREROUTING -t nat -p tcp --dport 26 -j REDIRECT --to-port 25
I tried this unsuccessfully and wondered if anyone had been able to implement successfully. What I am particularly confused by is why this would be PREROUTING. Surely it would be POSTROUTING to achieve what I want to do (i.e. redirect port 25 traffic to port 26).
Thanks.<br><br>Post edited by: martynw, at: 2008/12/31 13:27
