I can telnet to port 587 on my server and get a warm welcome from postfix
I cannot telnet to port 25, connection times out (as it should)
It is a fresh install of Virtualmin and I need to close this. How would I do this? And why is it open in the first place? I changed nothing in the configs…
postconf -n
postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_sender_restrictions
postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_client_restrictions
postconf: warning: /etc/postfix/master.cf: undefined parameter: mua_helo_restrictions
allow_percent_hack = no
command_directory = /usr/sbin
config_directory = /etc/postfix
daemon_directory = /usr/libexec/postfix
data_directory = /var/lib/postfix
debug_peer_level = 2
debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin ddd $daemon_directory/$process_name $process_id & sleep 5
home_mailbox = Maildir/
html_directory = no
inet_interfaces = all
inet_protocols = all
mail_owner = postfix
mailbox_size_limit = 0
mailq_path = /usr/bin/mailq.postfix
manpage_directory = /usr/share/man
mydestination = $myhostname, localhost.$mydomain, localhost, srv2.scmscloud.nl
newaliases_path = /usr/bin/newaliases.postfix
queue_directory = /var/spool/postfix
readme_directory = /usr/share/doc/postfix-2.10.1/README_FILES
sample_directory = /usr/share/doc/postfix-2.10.1/samples
sender_dependent_default_transport_maps = hash:/etc/postfix/dependent
sendmail_path = /usr/sbin/sendmail.postfix
setgid_group = postdrop
smtp_tls_security_level = may
smtpd_recipient_restrictions = permit_mynetworks permit_sasl_authenticated reject_unauth_destination reject
smtpd_sasl_auth_enable = yes
smtpd_tls_CAfile = /etc/postfix/postfix.ca.pem
smtpd_tls_cert_file = /etc/postfix/postfix.cert.pem
smtpd_tls_key_file = /etc/postfix/postfix.key.pem
smtpd_tls_mandatory_protocols = !SSLv2, !SSLv3
smtpd_tls_security_level = may
unknown_local_recipient_reject_code = 550
Hope someone can help
