rulez22
February 10, 2012, 10:29am
#1
In Postfix getting tons of these errors (it arrives to root mail), particular with Google mail servers:
Transcript of session follows.
Out: 220 mywebsite.co.uk ESMTP Postfix
In: EHLO mail-wi0-f182.google.com
Out: 250-mywebsite.co.uk
Out: 250-PIPELINING
Out: 250-SIZE 10240000
Out: 250-VRFY
Out: 250-ETRN
Out: 250-STARTTLS
Out: 250-AUTH PLAIN LOGIN
Out: 250-AUTH=PLAIN LOGIN
Out: 250-ENHANCEDSTATUSCODES
Out: 250-8BITMIME
Out: 250 DSN
In: STARTTLS
Out: 454 4.7.0 TLS not available due to local problem
In: QUIT
Out: 221 2.0.0 Bye
For other details, see the local mail logfile
What’s the solution here?
Cheers
rulez22
February 10, 2012, 10:34am
#2
Also getting loads of these:
In: EHLO multimatics.hosting24.com.au
Out: 250-PIPELINING
Out: 250-VRFY
Out: 250-ETRN
Out: 250-STARTTLS
Out: 250-8BITMIME
Out: 250 DSN
In: STARTTLS
In: MAIL FROM:ds@seamessenger.com.au
Out: 250 2.1.0 Ok
In: RCPT TO:myuser@mywebsite.co.uk
Out: 450 4.2.0 myuser@mywebsite.co.uk : Recipient address rejected:
Greylisted, see http://postgrey.schweikert.ch/help/mywebsite.co.uk.html
In: QUIT
Out: 221 2.0.0 Bye
myuser@mywebsite.co.uk - is my real address, so is mywebsite.co.uk
Eric
February 10, 2012, 2:40pm
#3
I’m not sure what the “TLS not available due to local problem” error is. You may want to look in your mail logs, /var/log/maillog or /var/log/mail.log, in order to get more details.
In your second post, you saw the notice “Recipient address rejected: Greylisted”.
That just means that greylisting is active on your server.
That can be enabled or disabled in Email Messages -> Email Greylisting. We recommend using that though, as it’s a great way to reduce spam.
rulez22
February 14, 2012, 5:00pm
#4
Feb 13 21:34:34 ip-ip-ip-ip postfix/smtpd[7923]: warning: cannot get RSA certificate from file /etc/postfix/postfix.cert.pem: disabling TLS support
Feb 13 21:34:34 ip-ip-ip-ip postfix/smtpd[7923]: warning: TLS library problem: 7923:error:02001002:system library:fopen:No such file or directory:bss_file.c:355:fopen(’/etc/postfix/postfix.cert.pem’,‘r’):
Feb 13 21:34:34 ip-ip-ip-ip postfix/smtpd[7923]: warning: TLS library problem: 7923:error:20074002:BIO routines:FILE_CTRL:system lib:bss_file.c:357:
Feb 13 21:34:34 ip-ip-ip-ip postfix/smtpd[7923]: warning: TLS library problem: 7923:error:140DC002:SSL routines:SSL_CTX_use_certificate_chain_file:system lib:ssl_rsa.c:722:
Feb 13 21:34:34 ip-ip-ip-ip postfix/smtpd[7923]: connect from mail-ww0-f46.google.com [74.125.82.46]
rulez22
February 21, 2012, 12:06pm
#5
this was fixed with creating an SSL certificate in Webmin/Poxtfix
