I can receive email from anyone, and I can send email to other domains on my server.
When I try to send email to an @gmail.com address, for example, the email shows up in my Mail Queue, but they just sit there. I’ve tried flushing the queue, but they still just sit there.
There is nothing in the “Status” column to alert me to any problems…
# sh postfinger.sh
postfinger - postfix configuration on Tue Oct 13 20:39:28 CDT 2015
version: 1.30
Warning: postfinger output may show private configuration information,
such as ip addresses and/or domain names which you do not want to show
to the public. If this is the case it is your responsibility to modify
the output to hide this private information. [Remove this warning with
the --nowarn option.]
--System Parameters--
mail_version = 2.10.1
hostname = bit-01
uname = Linux bit-01 2.6.32-042stab108.5 #1 SMP Wed Jun 17 20:20:17 MSK 2015 x86_64 x86_64 x86_64 GNU/Linux
--Packaging information--
looks like this postfix comes from RPM package: postfix-2.10.1-6.el7.x86_64
--main.cf non-default parameters--
allow_percent_hack = no
debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin ddd $daemon_directory/$process_name $process_id & sleep 5
home_mailbox = Maildir/
mailbox_size_limit = 0
mailq_path = /usr/bin/mailq.postfix
manpage_directory = /usr/share/man
mydestination = $myhostname, localhost
mydomain = *****.com
myhostname = ***.***.*****.com
mynetworks_style = host
newaliases_path = /usr/bin/newaliases.postfix
readme_directory = /usr/share/doc/postfix-2.10.1/README_FILES
sample_directory = /usr/share/doc/postfix-2.10.1/samples
sendmail_path = /usr/sbin/sendmail.postfix
smtp_sasl_auth_enable = yes
smtpd_banner = ***.***.*****.com ESMTP Hello
smtpd_client_restrictions = permit_inet_interfaces permit_tls_all_clientcerts
smtpd_helo_required = yes
smtpd_tls_cert_file = /etc/postfix/cert/postfix.pem
smtpd_use_tls = yes
--master.cf--
smtp inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes
pickup unix n - n 60 1 pickup
cleanup unix n - n - 0 cleanup
qmgr unix n - n 300 1 qmgr
tlsmgr unix - - n 1000? 1 tlsmgr
rewrite unix - - n - - trivial-rewrite
bounce unix - - n - 0 bounce
defer unix - - n - 0 bounce
trace unix - - n - 0 bounce
verify unix - - n - 1 verify
flush unix n - n 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - n - - smtp
relay unix - - n - - smtp
showq unix n - n - - showq
error unix - - n - - error
retry unix - - n - - error
discard unix - - n - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - n - - lmtp
anvil unix - - n - 1 anvil
scache unix - - n - 1 scache
submission inet n - n - - smtpd -o smtpd_sasl_auth_enable=yes
-- end of postfinger output --
