I am setting up osTicket on a virtualmin virtual server and when it tries to mail out, I get these issues:
maillog:
Aug 19 16:32:20 servername postfix/smtp[30348]: E1F9E20E0867: to=info@domain.net , relay=none, delay=6329, delays=6299/0.03/30/0, dsn=4.4.1, status=deferred (connect to mail.mydomain.com [xxx.xxx.xxx.xxx]: Connection timed out)
Aug 19 16:32:20 servername postfix/qmgr[3174]: E3DAE20E0866: to=info@domain.net , relay=none, delay=10358, delays=10328/30/0/0, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to mail.mydomain.com [xxx.xxx.xxx.xxx]: Connection timed out)
Aug 19 16:32:20 servername postfix/qmgr[3174]: E7DD820E085F: to=first.last@domain.net , relay=none, delay=6497, delays=6467/30/0/0, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to mail.mydomain.com [xxx.xxx.xxx.xxx]: Connection timed out)
Aug 19 16:32:20 servername postfix/qmgr[3174]: E5A5420E0860: to=first.last@domain.net , relay=none, delay=3859, delays=3829/30/0/0, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to mail.mydomain.com [xxx.xxx.xxx.xxx]: Connection timed out)
Aug 19 16:32:20 servername postfix/qmgr[3174]: E9A3120E0861: to=info@domain.net , relay=none, delay=6497, delays=6467/30/0/0, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to mail.mydomain.com [xxx.xxx.xxx.xxx]: Connection timed out)
Aug 19 16:32:20 servername postfix/qmgr[3174]: EAFB620E0864: to=first.last@domain.net , relay=none, delay=59500, delays=59470/30/0/0, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to mail.mydomain.com [xxx.xxx.xxx.xxx]: Connection timed out)
Aug 19 16:32:20 servername postfix/qmgr[3174]: EBDEA20E085E: to=first.last@domain.net , relay=none, delay=318708, delays=318678/30/0/0, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to mail.mydomain.com [xxx.xxx.xxx.xxx]: Connection timed out)
I can mail to a @gmail.com account no problem. But as soon as I try to mail to an @domain.net address it has issues reaching our internal mail server, the @domain.net server.
Any ideas?
ronald
August 20, 2009, 4:58pm
2
Your MX records that were reported by your nameservers are:
0 mx-12-173-187-97.mobiusllc.net 12.173.187.97
that is incorrect and your mailserver can not be reached.
5 mail.mobiusllc.net 12.173.187.97 would be correct. you need to change your zonefile/mx records.
ronald
August 20, 2009, 11:16pm
4
no it isn’t
5 12.173.187.97.mobiusllc.net No A Record (no glue either)
you can check here: http://www.intodns.com/mobiusllc.net
Ok it does not seem to have that error anymore. MX Looks good otherwise.
But my mail internally from the web server seems to still be timing out. If it helps at all check out m y SF post as well for some more troubleshooting steps I have taken.
http://serverfault.com/questions/56679/postfix-connection-timed-out-internal-issue
Eric
August 21, 2009, 3:13am
6
So, the server where you’re receiving the timeouts – is that your Virtualmin or your Zimbra server?
And, if you were to log into said server, and type:
telnet localhost 25
Does it connect, or does that time out as well?
I am trying to send ticket notifications from a webapp called osTicket on the virtualmin box to email addresses on the local Zimbra box.
When I telnet from the virtualmin box to the zimbra box I get:
[user@hostname log]$ sudo telnet mx-xx-xx-xx-xx.mailserver.com 25 Password: Trying 192.xxx.xxx.xxx… Connected to mx-xx-xx-xx-xx.mailserver.com (192.xxx.xxx.xxx). Escape character is ‘^]’. 220 mail.mailserver.com ESMTP Postfix
This is what was returned. It looks good right?
Eric
August 21, 2009, 4:21am
8
Yeah, that much looks good.
So, the address you’re emailing – is that “mobiusllc.net ”?
On your Virtualmin box, if you type “dig mx mobiusllc.net ” – what do you get?
From there, what happens if you telnet into the IP address you got from the previous command – does that work, or timeout?
I also tried to telnet to the internal address at 192.xxx.xxx.xxx and I get the :
sudo telnet mx-12-173-187-97.mobiusllc.net 25 Trying 192.xxx.xxx.xxx… Connected to mx-12-173-187-97.mobiusllc.net (192.xxx.xxx.xxx). Escape character is ‘^]’. 220 mail.mobiusllc.net ESMTP
[user@hostname ~]$ sudo telnet mx-12-173-187-97.mobiusllc.net 25
220 mail.mobiusllc.net ESMTP Postfix
quit
Connection closed by foreign host.
[user@host ~]$ sudo telnet 12.173.187.97 25
Trying 12.173.187.97…
telnet: connect to address 12.173.187.97: Connection timed out
telnet: Unable to connect to remote host: Connection timed out
But notice if I telnet to mx-12- etc. etc. etc. it gives a different response. Could that be because the firewall blocks ICMP (ping) traffic?
ronald
August 21, 2009, 5:00pm
11
may be far fetched but did you try to install something else besides OsTicket to test if another script has the same issues?
Ya, unfortunately it is every other app. I have CATS Applicant Tracking System as well as a Drupal install having the same issues. It is ONLY to internal email addresses though. (To the Zimbra mail server on the same network) If I have the scripts send email to external mail servers it works great.
I can’t help but think its running into an issue going outside to the WAN then coming back in.
Is there any way I could force it to go directly to the internal IP of the local mail server when mailing to @mobiusllc.net addresses? I think that would fix it I just don’t know how to do it.
Eric
August 22, 2009, 12:28am
13
Sure – you could add an entry for the hostname that isn’t working into your /etc/hosts file.
If the name that’s failing is “mail.mydomain.com ”, you could add an entry like:
192.xxx.xxx.xxx mail.mydomain.com
Ok so it looks like I have already tried that route. If that does not work, any other ideas?
This is the part that I find so odd. I have my /etc/hosts like this:
127.0.0.1 host localhost.localdomain localhost
::1 localhost6.localdomain6 localhost6
192.168.xxx.xxx host.domain.com domain.com
192.168.xxx.xxx mx-12-173-187-97.mobiusllc.net
192.168.xxx.xxx mail.mobiusllc.net
yet its still showing mx-12-173-187-97.mobiusllc.net [12.173.187.97] in maillog
Aug 21 16:45:53 host postfix/qmgr[3166]: A1D1620E087F: to=user@mobiusllc.net , relay=none, delay=12353, delays=12323/30/0/0, dsn=4.4.1, staatus=deferred (delivery temporarily suspended: connect to mx-12-173-187-97.mobiusllc.net [12.173.187.97]: Connection timed out)
However when I ping it, I get the internal…:
sudo ping mx-12-173-187-97.mobiusllc.net
PING mx-12-173-187-97.mobiusllc.net (192.168.xxx.xxx) 56(84) bytes of data.
64 bytes from mx-12-173-187-97.mobiusllc.net (192.168.xxx.xxx): icmp_seq=1 ttl=64 time=0.138 ms
64 bytes from mx-12-173-187-97.mobiusllc.net (192.168.xxx.xxx): icmp_seq=2 ttl=64 time=0.121 ms
64 bytes from mx-12-173-187-97.mobiusllc.net (192.168.xxx.xxx): icmp_seq=3 ttl=64 time=0.118 ms
Is there something I need to do to the postfix config? main.cf or something?
I will give anyone that can help fix this $100 via paypal.
Eric
August 24, 2009, 4:11pm
17
Well, I’m guessing the issue is, as you mentioned earlier, due to having both an internal and external address.
I suspect that the DNS lookup Postfix is performing doesn’t use the hosts file – it may be using DNS to lookup the MX record.
What that means is that you may need to use a BIND View in order to get the setup you have working.
That is, you’d need to setup BIND to give out one IP address if the request comes from inside your LAN, and another IP address if it’s coming from the outside.
Odd. I changed my primary DNS server on the Virtualmin box then went to BIND and clicked the root zone, then chose to Re-download Root Name Servers…then flushed the Queue. Now it works. Weird.
Can you please delete this topic?
; <<>> DiG 9.3.4-P1 <<>> mx domain.net
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 6896
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 2, ADDITIONAL: 3
;; QUESTION SECTION:
;domain.net . IN MX
;; ANSWER SECTION:
domain.net . 14400 IN MX 5 mx-12-173-187-97.domain.net .
;; AUTHORITY SECTION:
domain.net . 51029 IN NS ns2.domain.net .
domain.net . 51029 IN NS ns1.domain.net .
;; ADDITIONAL SECTION:
mx-12-173-187-97.domain.net . 14400 IN A 12.173.187.97
ns1.domain.net . 172800 IN A 64.22.66.229
ns2.domain.net . 172800 IN A 64.22.66.230
;; Query time: 1779 msec
;; SERVER: 12.127.17.71#53(12.127.17.71)
;; WHEN: Thu Aug 20 21:58:10 2009
;; MSG SIZE rcvd: 148
