Postfix Issue - Receiving but no delivery to mailboxes?
OS type and version Ubuntu Server 20.04
Webmin version 2.021
Virtualmin version 7.5
Related packages Postfix
Hi! So another day, another problem to overcome!
I recently attempted to lessen “backscatter” spam, and inadvertently botched something. I followed a couple of GeoIP blocking guides, and it stopped any and all mail from reaching my server at all. I’ve unwound what I “thought” was all the alterations, however, now the server receives the emails, but doesn’t deliver them to the mailboxes of all domains & users. I attempted install of postscreen, and GeoIP Postfix Block.
Here is a copy of my main.cf
#See /usr/share/postfix/main.cf.dist for a commented, more complete version
#Debian specific: Specifying a file name will cause the first
#line of that file to be used as the name. The Debian default
#is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
#appending .domain is the MUA’s job.
append_dot_mydomain = no
#Uncomment the next line to generate “delayed mail” warnings
#delay_warning_time = 4h
readme_directory = no
#See http://www.postfix.org/COMPATIBILITY_README.html – default to 2 on
#fresh installs.
compatibility_level = 2
#TLS parameters
smtpd_tls_cert_file = /etc/postfix/postfix.cert.pem
smtpd_tls_key_file = /etc/postfix/postfix.key.pem
smtpd_tls_security_level = may
smtp_tls_CApath=/etc/ssl/certs
smtp_tls_security_level = dane
smtpd_relay_restrictions = defer_unauth_destination permit_mynetworks permit_inet_interfaces permit_sasl_authenticated
myhostname = rread.co.uk
mydestination = $myhostname, rread.co.uk, localhost.co.uk, , localhost
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
inet_protocols = all
sender_dependent_default_transport_maps = hash:/etc/postfix/dependent
home_mailbox = Maildir/
smtp_dns_support_level = dnssec
smtp_host_lookup = dns
allow_percent_hack = no
resolve_dequoted_address = no
tls_server_sni_maps = hash:/etc/postfix/sni_map
smtpd_tls_CAfile = /etc/postfix/postfix.ca.pem
smtpd_tls_mandatory_protocols = !SSLv2, !SSLv3, !TLSv1, !TLSv1.1
milter_default_action = accept
smtpd_milters = inet:localhost:8891
non_smtpd_milters = inet:localhost:8891smtpd_recipient_restrictions = permit_sasl_authenticated
and this is the master, where I hashed and unhashed a couple of entries.
#Postfix master process configuration file. For details on the format
#of the file, see the master(5) manual page (command: “man 5 master” or
#on-line: http://www.postfix.org/master.5.html).
#Do not forget to execute “postfix reload” after editing this file.
#service type private unpriv chroot wakeup maxproc command + args
(yes) (yes) (no) (never) (100)
#smtp inet n - y - - smtpd -o smtpd_sasl_auth_enable=yes -o smtpd_tls_security_level=may
smtp inet n - y - 1 postscreen
smtpd pass - - y - - smtpd
dnsblog unix - - y - 0 dnsblog
tlsproxy unix - - y - 0 tlsproxy
submission inet n - y - - smtpd
#-o syslog_name=postfix/submission
#-o smtpd_tls_security_level=encrypt
#-o smtpd_sasl_auth_enable=yes
#-o smtpd_tls_auth_only=yes
#-o smtpd_reject_unlisted_recipient=no
#-o smtpd_client_restrictions=$mua_client_restrictions
#-o smtpd_helo_restrictions=$mua_helo_restrictions
#-o smtpd_sender_restrictions=$mua_sender_restrictions
#-o smtpd_recipient_restrictions=
#-o smtpd_relay_restrictions=permit_sasl_authenticated,reject
#-o milter_macro_daemon_name=ORIGINATING
#smtps inet n - y - - smtpd
#-o syslog_name=postfix/smtps
#-o smtpd_tls_wrappermode=yes
#628 inet n - y - - qmqpd
pickup unix n - y 60 1 pickup
cleanup unix n - y - 0 cleanup
qmgr unix n - n 300 1 qmgr
#qmgr unix n - n 300 1 oqmgr
tlsmgr unix - - y 1000? 1 tlsmgr
rewrite unix - - y - - trivial-rewrite
bounce unix - - y - 0 bounce
defer unix - - y - 0 bounce
trace unix - - y - 0 bounce
verify unix - - y - 1 verify
flush unix n - y 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - y - - smtp
relay unix - - y - - smtp
-o syslog_name=postfix/$service_name
#-o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - y - - showq
error unix - - y - - error
retry unix - - y - - error
discard unix - - y - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - y - - lmtp
anvil unix - - y - 1 anvil
scache unix - - y - 1 scache
postlog unix-dgram n - n - 1 postlogd
#Interfaces to non-Postfix software. Be sure to examine the manual
#pages of the non-Postfix software to find out what options it wants.
#Many of the following services use the Postfix pipe(8) delivery
#agent. See the pipe(8) man page for information about ${recipient}
#and other message envelope options.
#maildrop. See the Postfix MAILDROP_README file for details.
#Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
#Recent Cyrus versions can use the existing “lmtp” master.cf entry.
#Specify in cyrus.conf:
lmtp cmd=“lmtpd -a” listen=“localhost:lmtp” proto=tcp4
#Specify in main.cf one or more of the following:
#mailbox_transport = lmtp:inet:localhost
#virtual_transport = lmtp:inet:localhost
#Cyrus 2.1.5 (Amos Gouaux)
#Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
#user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
#Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
#flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
#See the Postfix UUCP_README file for configuration details.
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
#Other external delivery methods.
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman unix - n n - - pipe
flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
${nexthop} ${user}
submission inet n - y - - smtpd -o smtpd_sasl_auth_enable=yes -o smtpd_tls_security_level=may
smtps inet n - y - - smtpd -o smtpd_sasl_auth_enable=yes -o smtpd_tls_security_level=may -o smtpd_tls_wrappermode=yes
I think I’m going to take backup of configs before I twiddle with any more LOLOLOL.
Cheers for your inevitable responses, and I’d applaud any name calling due to my marvellous ability to right ol’ make a mess of any and all things Virtualmin :stuck_out_tongue:
We need to see the logs.
First, the relevant entries from the mail.log for one specific lost mail (or, maybe the journal for Postfix) to make sure it is making it to procmail, and then the procmail log to see what procmail is doing with it (assuming it’s actually making it to procmail).
mail.log
Apr 2 00:00:13 rread postgrey[1781]: action=greylist, reason=new, client_name=138-36-121-50.reverso.urupesnet.com.br, client_address=138.36.121.50/32, sender=james@smart-guy.co.uk, recipient=nobodyspecial5051@yahoo.com
Apr 2 00:00:13 rread postfix/smtpd[69311]: NOQUEUE: reject: RCPT from 138-36-121-50.reverso.urupesnet.com.br[138.36.121.50]: 454 4.7.1 nobodyspecial5051@yahoo.com: Relay access denied; from=james@smart-guy.co.uk to=nobodyspecial5051@yahoo.com proto=ESMTP helo=
Apr 2 00:00:14 rread postfix/smtpd[69311]: lost connection after DATA from 138-36-121-50.reverso.urupesnet.com.br[138.36.121.50]
Apr 2 00:00:14 rread postfix/smtpd[69311]: disconnect from 138-36-121-50.reverso.urupesnet.com.br[138.36.121.50] ehlo=1 auth=1 mail=1 rcpt=0/1 data=0/1 commands=3/5
Apr 2 00:00:15 rread postgrey[1781]: action=greylist, reason=new, client_name=unknown, client_address=178.128.14.3/32, sender=james@smart-guy.co.uk, recipient=azoyayoungest@gmail.com
Apr 2 00:00:15 rread postfix/smtpd[69487]: NOQUEUE: reject: RCPT from unknown[178.128.14.3]: 454 4.7.1 azoyayoungest@gmail.com: Relay access denied; from=james@smart-guy.co.uk to=azoyayoungest@gmail.com proto=ESMTP helo=
Apr 2 00:00:15 rread postfix/smtpd[69487]: lost connection after DATA from unknown[178.128.14.3]
Apr 2 00:00:15 rread postfix/smtpd[69487]: disconnect from unknown[178.128.14.3] helo=1 ehlo=1 starttls=1 auth=1 mail=1 rcpt=0/1 data=0/1 commands=5/7
Apr 2 00:00:16 rread postgrey[1781]: action=greylist, reason=new, client_name=unknown, client_address=103.75.34.230/32, sender=james@smart-guy.co.uk, recipient=guiguit94@live.fr
Apr 2 00:00:16 rread postfix/smtpd[69488]: NOQUEUE: reject: RCPT from unknown[103.75.34.230]: 454 4.7.1 guiguit94@live.fr: Relay access denied; from=james@smart-guy.co.uk to=guiguit94@live.fr proto=ESMTP helo=
Apr 2 00:00:17 rread postfix/smtpd[69488]: lost connection after DATA from unknown[103.75.34.230]
Apr 2 00:00:17 rread postfix/smtpd[69488]: disconnect from unknown[103.75.34.230] helo=1 ehlo=1 starttls=1 auth=1 mail=1 rcpt=0/1 data=0/1 commands=5/7
Apr 2 00:00:18 rread postfix/smtpd[69487]: warning: hostname 187-44-211-118.STATIC.itsweb.com.br does not resolve to address 187.44.211.118: Name or service not known
Apr 2 00:00:18 rread postfix/smtpd[69487]: connect from unknown[187.44.211.118]
Apr 2 00:00:22 rread postgrey[1781]: action=greylist, reason=new, client_name=unknown, client_address=187.44.211.118/32, sender=james@smart-guy.co.uk, recipient=mulengihma2008@hotmail.com
Apr 2 00:00:22 rread postfix/smtpd[69487]: NOQUEUE: reject: RCPT from unknown[187.44.211.118]: 454 4.7.1 mulengihma2008@hotmail.com: Relay access denied; from=james@smart-guy.co.uk to=mulengihma2008@hotmail.com proto=ESMTP helo=
Apr 2 00:00:23 rread postfix/smtpd[69487]: lost connection after DATA from unknown[187.44.211.118]
Apr 2 00:00:23 rread postfix/smtpd[69487]: disconnect from unknown[187.44.211.118] helo=1 ehlo=1 starttls=1 auth=1 mail=1 rcpt=0/1 data=0/1 commands=5/7
Apr 2 00:01:14 rread postfix/smtpd[69487]: warning: hostname ptr.reditmx.com does not resolve to address 189.201.189.146: Name or service not known
Apr 2 00:01:14 rread postfix/smtpd[69487]: connect from unknown[189.201.189.146]
Apr 2 00:01:16 rread postgrey[1781]: action=greylist, reason=new, client_name=unknown, client_address=189.201.189.146/32, sender=james@smart-guy.co.uk, recipient=ccoolman36@aol.com
Apr 2 00:01:16 rread postfix/smtpd[69487]: NOQUEUE: reject: RCPT from unknown[189.201.189.146]: 454 4.7.1 ccoolman36@aol.com: Relay access denied; from=james@smart-guy.co.uk to=ccoolman36@aol.com proto=ESMTP helo=
Apr 2 00:01:16 rread postfix/smtpd[69487]: lost connection after DATA from unknown[189.201.189.146]
Apr 2 00:01:16 rread postfix/smtpd[69487]: disconnect from unknown[189.201.189.146] ehlo=1 auth=1 mail=1 rcpt=0/1 data=0/1 commands=3/5
Apr 2 00:01:47 rread dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=162.243.152.15, lip=192.168.0.20, TLS handshaking: SSL_accept() failed: error:1408F10B:SSL routines:ssl3_get_record:wrong version number, session=<8OJ0T074+Kai85gP>
Apr 2 00:01:56 rread postfix/qmgr[39448]: 428DCC6174D: from=netdata@rread.co.uk, size=44593, nrcpt=1 (queue active)
Apr 2 00:01:56 rread postfix/trivial-rewrite[69077]: warning: do not list domain rread.co.uk in BOTH mydestination and virtual_alias_domains
Apr 2 00:01:56 rread postfix/qmgr[39448]: A1010C60C72: from=jamesread90@gmail.com, size=2879, nrcpt=1 (queue active)
Apr 2 00:01:56 rread postfix/local[71298]: error: open database /etc/aliases.db: No such file or directory
Apr 2 00:01:56 rread postfix/local[71298]: warning: hash:/etc/aliases is unavailable. open database /etc/aliases.db: No such file or directory
Apr 2 00:01:56 rread postfix/local[71298]: warning: hash:/etc/aliases: lookup of ‘root’ failed
Apr 2 00:01:56 rread postfix/local[71299]: error: open database /etc/aliases.db: No such file or directory
Apr 2 00:01:56 rread postfix/local[71299]: warning: hash:/etc/aliases is unavailable. open database /etc/aliases.db: No such file or directory
Apr 2 00:01:56 rread postfix/local[71299]: warning: hash:/etc/aliases: lookup of ‘james@rread.co.uk’ failed
Apr 2 00:01:56 rread postfix/local[71299]: A1010C60C72: to=<james@rread.co.uk@rread.co.uk>, orig_to=james@rread.co.uk, relay=local, delay=9075, delays=9074/0.01/0/0.06, dsn=4.3.0, status=deferred (alias database unavailable)
Apr 2 00:01:56 rread postfix/local[71298]: 428DCC6174D: to=root@rread.co.uk, orig_to=, relay=local, delay=8954, delays=8954/0.01/0/0.06, dsn=4.3.0, status=deferred (alias database unavailable)
Apr 2 00:01:57 rread postfix/anvil[39508]: statistics: max connection rate 2/60s for (submission:77.73.24.206) at Apr 1 23:52:08
Apr 2 00:01:57 rread postfix/anvil[39508]: statistics: max connection count 1 for (submission:77.73.24.206) at Apr 1 23:52:08
Apr 2 00:01:57 rread postfix/anvil[39508]: statistics: max cache size 12 at Apr 1 23:52:09
Apr 2 00:02:15 rread postfix/smtpd[71325]: error: open database /etc/aliases.db: No such file or directory
Apr 2 00:02:15 rread postfix/smtpd[69487]: connect from eth-231.48-homell.natm.ru[84.242.231.48]
Apr 2 00:02:15 rread postfix/smtpd[71325]: connect from mk.grand-prix.ru[77.73.24.206]
Apr 2 00:02:15 rread postfix/smtpd[71327]: error: open database /etc/aliases.db: No such file or directory
Apr 2 00:02:16 rread postfix/smtpd[71329]: error: open database /etc/aliases.db: No such file or directory
Apr 2 00:02:16 rread postfix/smtpd[71329]: connect from delivery.antispam.mailspamprotection.com[185.56.87.12]
Apr 2 00:02:16 rread postgrey[1781]: action=greylist, reason=new, client_name=eth-231.48-homell.natm.ru, client_address=84.242.231.48/32, sender=james@smart-guy.co.uk, recipient=foxhaund11@gmail.com
Apr 2 00:02:16 rread postfix/smtpd[69487]: NOQUEUE: reject: RCPT from eth-231.48-homell.natm.ru[84.242.231.48]: 454 4.7.1 foxhaund11@gmail.com: Relay access denied; from=james@smart-guy.co.uk to=foxhaund11@gmail.com proto=ESMTP helo=
Apr 2 00:02:16 rread postfix/trivial-rewrite[69077]: warning: do not list domain rread.co.uk in BOTH mydestination and virtual_alias_domains
Apr 2 00:02:16 rread postfix/smtpd[69487]: lost connection after DATA from eth-231.48-homell.natm.ru[84.242.231.48]
Apr 2 00:02:16 rread postfix/smtpd[69487]: disconnect from eth-231.48-homell.natm.ru[84.242.231.48] ehlo=1 auth=1 mail=1 rcpt=0/1 data=0/1 commands=3/5
Apr 2 00:02:16 rread postgrey[1781]: action=pass, reason=triplet found, delay=9794, client_name=delivery.antispam.mailspamprotection.com, client_address=185.56.87.12/32, recipient=james@smart-guy.co.uk
Apr 2 00:02:16 rread postfix/smtpd[71329]: 5D56CC62170: client=delivery.antispam.mailspamprotection.com[185.56.87.12]
Apr 2 00:02:16 rread postfix/cleanup[71330]: 5D56CC62170: message-id=E1piE6H-000DNt-34@c106103.sgvps.net
Apr 2 00:02:16 rread postfix/smtpd[71327]: connect from xc1cc.mdn.nusa.net.id[202.162.193.204]
Apr 2 00:02:16 rread opendkim[1278]: 5D56CC62170: s=default d=segurosbonilla.com a=rsa-sha256 SSL
Apr 2 00:02:16 rread postfix/qmgr[39448]: 5D56CC62170: from=<>, size=4303, nrcpt=1 (queue active)
Apr 2 00:02:16 rread postfix/local[71299]: warning: hash:/etc/aliases is unavailable. open database /etc/aliases.db: No such file or directory
Apr 2 00:02:16 rread postfix/local[71299]: warning: hash:/etc/aliases: lookup of ‘james@smart-guy.co.uk’ failed
Apr 2 00:02:16 rread postfix/smtpd[71329]: disconnect from delivery.antispam.mailspamprotection.com[185.56.87.12] ehlo=2 starttls=1 mail=1 rcpt=1 bdat=1 quit=1 commands=7
Apr 2 00:02:16 rread postfix/local[71299]: 5D56CC62170: to=<james@smart-guy.co.uk@rread.co.uk>, orig_to=james@smart-guy.co.uk, relay=local, delay=0.26, delays=0.23/0/0/0.03, dsn=4.3.0, status=deferred (alias database unavailable)
Apr 2 00:02:16 rread postgrey[1781]: action=greylist, reason=new, client_name=mk.grand-prix.ru, client_address=77.73.24.206/32, sender=james@smart-guy.co.uk, recipient=michaelg.one@gmail.com
Apr 2 00:02:16 rread postfix/smtpd[71325]: NOQUEUE: reject: RCPT from mk.grand-prix.ru[77.73.24.206]: 454 4.7.1 michaelg.one@gmail.com: Relay access denied; from=james@smart-guy.co.uk to=michaelg.one@gmail.com proto=ESMTP helo=
Apr 2 00:02:17 rread postfix/smtpd[71325]: lost connection after DATA from mk.grand-prix.ru[77.73.24.206]
Apr 2 00:02:17 rread postfix/smtpd[71325]: disconnect from mk.grand-prix.ru[77.73.24.206] helo=1 ehlo=1 starttls=1 auth=1 mail=1 rcpt=0/1 data=0/1 commands=5/7
Apr 2 00:02:18 rread postfix/smtpd[69487]: warning: hostname 197.254.4.250.acesskenya.net does not resolve to address 197.254.4.250
Apr 2 00:02:18 rread postfix/smtpd[69487]: connect from unknown[197.254.4.250]
Apr 2 00:02:18 rread postgrey[1781]: action=greylist, reason=new, client_name=xc1cc.mdn.nusa.net.id, client_address=202.162.193.204/32, sender=james@smart-guy.co.uk, recipient=hamayoonazimi10@gmail.com
Apr 2 00:02:18 rread postfix/smtpd[71327]: NOQUEUE: reject: RCPT from xc1cc.mdn.nusa.net.id[202.162.193.204]: 454 4.7.1 hamayoonazimi10@gmail.com: Relay access denied; from=james@smart-guy.co.uk to=hamayoonazimi10@gmail.com proto=ESMTP helo=
Apr 2 00:02:19 rread postfix/smtpd[71327]: lost connection after DATA from xc1cc.mdn.nusa.net.id[202.162.193.204]
Apr 2 00:02:19 rread postfix/smtpd[71327]: disconnect from xc1cc.mdn.nusa.net.id[202.162.193.204] ehlo=1 auth=1 mail=1 rcpt=0/1 data=0/1 commands=3/5
Apr 2 00:02:20 rread postgrey[1781]: action=greylist, reason=new, client_name=unknown, client_address=197.254.4.250/32, sender=james@smart-guy.co.uk, recipient=mwdmaddog@msn.com
Apr 2 00:02:20 rread postfix/smtpd[69487]: NOQUEUE: reject: RCPT from unknown[197.254.4.250]: 454 4.7.1 mwdmaddog@msn.com: Relay access denied; from=james@smart-guy.co.uk to=mwdmaddog@msn.com proto=ESMTP helo=
Apr 2 00:02:21 rread postfix/smtpd[69487]: lost connection after DATA from unknown[197.254.4.250]
Apr 2 00:02:21 rread postfix/smtpd[69487]: disconnect from unknown[197.254.4.250] ehlo=1 auth=1 mail=1 rcpt=0/1 data=0/1 commands=3/5
Apr 2 00:02:21 rread postfix/smtpd[71329]: warning: hostname ezecom.103.9.188.0.213.ezecom.com.kh does not resolve to address 103.9.188.213: Name or service not known
Apr 2 00:02:21 rread postfix/smtpd[71329]: connect from unknown[103.9.188.213]
Apr 2 00:02:22 rread postfix/smtpd[71329]: lost connection after STARTTLS from unknown[103.9.188.213]
Apr 2 00:02:22 rread postfix/smtpd[71329]: disconnect from unknown[103.9.188.213] ehlo=1 starttls=1 commands=2
Apr 2 00:02:36 rread postfix/smtpd[71325]: warning: hostname static-45.6.94.159-Locallink-Telecomunicacoes does not resolve to address 45.6.94.159: Name or service not known
Apr 2 00:02:36 rread postfix/smtpd[71325]: connect from unknown[45.6.94.159]
Apr 2 00:02:40 rread postgrey[1781]: action=greylist, reason=new, client_name=unknown, client_address=45.6.94.159/32, sender=james@smart-guy.co.uk, recipient=ste_18@hotmail.it
Apr 2 00:02:40 rread postfix/smtpd[71325]: NOQUEUE: reject: RCPT from unknown[45.6.94.159]: 454 4.7.1 ste_18@hotmail.it: Relay access denied; from=james@smart-guy.co.uk to=ste_18@hotmail.it proto=ESMTP helo=
Apr 2 00:02:40 rread postfix/smtpd[71325]: lost connection after DATA from unknown[45.6.94.159]
Apr 2 00:02:40 rread postfix/smtpd[71325]: disconnect from unknown[45.6.94.159] helo=1 ehlo=1 starttls=1 auth=1 mail=1 rcpt=0/1 data=0/1 commands=5/7
Apr 2 00:03:17 rread postfix/smtpd[71327]: connect from unknown[194.50.6.42]
Apr 2 00:03:18 rread postgrey[1781]: action=greylist, reason=new, client_name=unknown, client_address=194.50.6.42/32, sender=james@smart-guy.co.uk, recipient=john_erick_loayon@yahoo.com
Apr 2 00:03:18 rread postfix/smtpd[71327]: NOQUEUE: reject: RCPT from unknown[194.50.6.42]: 454 4.7.1 john_erick_loayon@yahoo.com: Relay access denied; from=james@smart-guy.co.uk to=john_erick_loayon@yahoo.com proto=ESMTP helo=
Apr 2 00:03:18 rread postfix/smtpd[71327]: lost connection after DATA from unknown[194.50.6.42]
procmail.log for today is empty :frowning:
We don’t need/want the whole mail log. Just the entries related to one mail that gets lost.
So I still have a huge issue with backscatter, but I’ve dug through the extesively spam bloated logs and found:
Apr 2 01:06:56 rread postfix/qmgr[39448]: 4EB8AC6174E: from=jamesread90@gmail.com, size=2838, nrcpt=1 (queue active)
Apr 2 01:06:56 rread postfix/trivial-rewrite[82872]: warning: do not list domain rread.co.uk in BOTH mydestination and virtual_alias_domains
Apr 2 01:06:56 rread postfix/qmgr[39448]: CE23DC6174B: from=jamesread90@gmail.com, size=2820, nrcpt=1 (queue active)
Apr 2 01:06:56 rread postfix/local[86989]: warning: hash:/etc/aliases is unavailable. open database /etc/aliases.db: No such file or directory
Apr 2 01:06:56 rread postfix/local[86989]: warning: hash:/etc/aliases: lookup of ‘james@smart-guy.co.uk’ failed
Apr 2 01:06:56 rread postfix/local[87081]: error: open database /etc/aliases.db: No such file or directory
Apr 2 01:06:56 rread postfix/local[87081]: warning: hash:/etc/aliases is unavailable. open database /etc/aliases.db: No such file or directory
Apr 2 01:06:56 rread postfix/local[87081]: warning: hash:/etc/aliases: lookup of ‘james@rread.co.uk’ failed
Apr 2 01:06:56 rread postfix/local[87081]: CE23DC6174B: to=<james@rread.co.uk@rread.co.uk>, orig_to=james@rread.co.uk, relay=local, delay=12787, delays=12787/0.01/0/0.04, dsn=4.3.0, status=deferred (alias database unavailable)
Apr 2 01:06:56 rread postfix/local[86989]: 4EB8AC6174E: to=<james@smart-guy.co.uk@rread.co.uk>, orig_to=james@smart-guy.co.uk, relay=local, delay=12786, delays=12786/0/0/0.05, dsn=4.3.0, status=deferred (alias database unavailable)
Is the issue something to do with alias database?
Muchos Gracias!
You named your server the same exact name as a domain you are hosting virtual mail for. You shouldn’t do that.
This is covered in the docs (linked from the download page under the link “fully qualified domain name”):
Fully qualified domain name
If your system does not have a fully qualified domain name (FQDN), the installer will stop and ask you to choose one. This is mandatory because many services rely on having a fully qualified domain name in order to function. Mail, in particular, but some Apache configurations and many of the Virtualmin-created configuration files, also require a valid fully qualified domain name to function correctly. A fully qualified domain name is one of the form “srv1.virtualmin.com”, or simply “virtualmin.com” (but do not use a name you’ll be hosting in Virtualmin). We recommend you choose a name that is not one for which you will be receiving mail, in order to simplify later configuration. A good choice is to use a name server designator, such as “ns1.virtualmin.com”. Some customers also choose something like “host1.virtualmin.com” or “primary.virtualmin.com”. Any of these would be valid and would satisfy the install script and the services that rely on this option. The install script will add this name to /etc/hosts, which will satisfy all local services. It is even better if this name resolves correctly when looked up from outside of the system–this requires the name be added to your DNS zone for the second level domain. If the Virtualmin server you are installing will be the authoritative name server for this zone, you can later use Webmin to add a record for this name to the zone.
Also note that’s wholly unrelated to your backscatter (or spam) issue that started this topic. If my answer doesn’t provide enough guidance to fix it, please open a new topic to discuss the new issue. (But, really, just name your server something that doesn’t conflict with a domain you’re hosting virtually…Virtualmin manages virtual hosts, including virtual mail. By naming your server the same as a domain in Virtualmin that receives mail, you told Postfix that is is virtually hosting the domain and also that the server itself is the domain. That doesn’t make sense! Postfix injured itself in its confusion!)
I’m aware the backscatter is caused by exterior involvement, its just another issue I need to learn about and tend to. I’ve changed the servers hostname to an unhosted subdomain, that is recorded in my freedns.afraid.org account, and added to the A names in Virtualmin DNS also!
Something so simple. Oddly the server didnt have issues with the FQDN being the same as the hostname UNTIL I began tweaking to resolve issues with backscatter - entirely stopping in and outgoing mails. Then undoing my changes, and expecting it to work as it once did, but it didnt.
Thanks Joe! I guess I’ll go find and break something else, and be back shortly to bother you again :innocent:
