SYSTEM INFORMATION | |
OS type and version | Ubuntu 22.04 |
Webmin version | ? |
Virtualmin version | 7.4.0 |
Webserver version | ? |
Related packages | install script |
When running the install script on a fresh Ubuntu 22.04, I get the following error upon configuring Postfix in phase 4 (excerpt from log file):
[2024-11-12 16:30:27 CET] [DEBUG] Phase 4 of 4: Configuration
[2024/11/12 16:30:27] [INFO] - Starting init-system log...
[2024/11/12 16:30:27] [INFO] - Total plugins to be run: 21
[2024/11/12 16:30:27] [INFO] - Configuring AWStats
[2024/11/12 16:30:28] [INFO] - Succeeded
[2024/11/12 16:30:28] [INFO] - Configuring Apache
[2024/11/12 16:30:28] [INFO] - Code: 0 Result: Site 000-default disabled.
To activate the new configuration, you need to run:
systemctl reload apache2
[2024/11/12 16:30:28] [INFO] - Code: 0 Result: Site default-ssl already disabled
[2024/11/12 16:30:28] [INFO] - Code: 0 Result: Considering dependency setenvif for ssl:
Module setenvif already enabled
Considering dependency mime for ssl:
Module mime already enabled
Considering dependency socache_shmcb for ssl:
Enabling module socache_shmcb.
Enabling module ssl.
See /usr/share/doc/apache2/README.Debian.gz on how to configure SSL and create self-signed certificates.
systemctl restart apache2
[2024/11/12 16:30:31] [INFO] - Code: 0 Result:
[2024/11/12 16:30:34] [INFO] - Succeeded
[2024/11/12 16:30:34] [INFO] - Configuring Bind
[2024/11/12 16:30:35] [INFO] - Succeeded
[2024/11/12 16:30:35] [INFO] - Configuring ClamAV
[2024/11/12 16:30:37] [INFO] - Succeeded
[2024/11/12 16:30:37] [INFO] - Configuring Dovecot
[2024/11/12 16:30:38] [INFO] - Succeeded
[2024/11/12 16:30:38] [INFO] - Configuring Etckeeper
[2024/11/12 16:30:38] [INFO] - Configuring Firewalld
[2024/11/12 16:30:38] [INFO] - Code: 0 Result: Warning: ZONE_ALREADY_SET: public
success
[2024/11/12 16:30:38] [INFO] - Code: 0 Result: Warning: ALREADY_ENABLED: 'ssh' already in 'public'
success
[2024/11/12 16:30:38] [INFO] - Code: 0 Result: Warning: ALREADY_ENABLED: ssh
success
[2024/11/12 16:30:39] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: No such file or directory
JSON blob:
{"nftables": [{"metainfo": {"json_schema_version": 1}}, {"add": {"rule": {"family": "inet", "table": "firewalld", "chain": "filter_IN_public_allow", "expr": [{"match": {"left": {"payload": {"protocol": "tc>
[2024/11/12 16:30:39] [INFO] - Code: 0 Result: success
JSON blob:
[2024/11/12 16:30:40] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: No such file or directory
JSON blob:
[2024/11/12 16:30:40] [INFO] - Code: 0 Result: success
[2024/11/12 16:30:40] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: Invalid argument
JSON blob:
{"nftables": [{"metainfo": {"json_schema_version": 1}}, {"add": {"ct helper": {"family": "inet", "table": "firewalld", "name": "helper-ftp-tcp", "type": "ftp", "protocol": "tcp"}}}, {"add": {"rule": {"fami>
JSON blob:
[2024/11/12 16:30:41] [INFO] - Code: 0 Result: success
[2024/11/12 16:30:41] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: No such file or directory
JSON blob:
JSON blob:
[2024/11/12 16:30:42] [INFO] - Code: 0 Result: success
[2024/11/12 16:30:42] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: No such file or directory
JSON blob:
JSON blob:
[2024/11/12 16:30:43] [INFO] - Code: 0 Result: success
[2024/11/12 16:30:43] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: No such file or directory
JSON blob:
JSON blob:
[2024/11/12 16:30:44] [INFO] - Code: 0 Result: success
[2024/11/12 16:30:44] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: No such file or directory
JSON blob:
{"nftables": [{"metainfo": {"json_schema_version": 1}}, {"add": {"rule": {"family": "inet", "table": "firewalld", "chain": "filter_IN_public_allow", "expr": [{"match": {"left": {"payload": {"protocol": "ip>
JSON blob:
[2024/11/12 16:30:45] [INFO] - Code: 0 Result: success
[2024/11/12 16:30:45] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: No such file or directory
JSON blob:
JSON blob:
[2024/11/12 16:30:46] [INFO] - Code: 0 Result: success
[2024/11/12 16:30:46] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: No such file or directory
JSON blob:
JSON blob:
[2024/11/12 16:30:47] [INFO] - Code: 0 Result: success
[2024/11/12 16:30:47] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: No such file or directory
JSON blob:
[2024/11/12 16:30:48] [INFO] - Code: 3328 Result: Error: COMMAND_FAILED: 'python-nftables' failed: internal:0:0-0: Error: Could not process rule: No such file or directory
JSON blob:
{"nftables": [{"metainfo": {"json_schema_version": 1}}, {"add": {"chain": {"family": "inet", "table": "firewalld", "name": "mangle_PREROUTING", "type": "filter", "hook": "prerouting", "prio": -140}}}, {"ad>
[2024/11/12 16:30:48] [INFO] - Succeeded
[2024/11/12 16:30:49] [INFO] - Configuring MariaDB
[2024/11/12 16:30:49] [INFO] - Succeeded
[2024/11/12 16:30:49] [INFO] - Configuring Postfix
[2024/11/12 16:30:49] [WARN] - Failed
[2024/11/12 16:30:49] [INFO] - Configuring ProFTPd
[2024/11/12 16:30:49] [INFO] - Generating a self-signed certificate for TLS.
[2024/11/12 16:30:49] [INFO] - Code: 0 Result: [REMOVED BY ME]
[2024/11/12 16:30:49] [INFO] - Code: 0 Result: Generating public/private ecdsa key pair.
Your identification has been saved in /etc/proftpd/ssh_host_ecdsa_key
Your public key has been saved in /etc/proftpd/ssh_host_ecdsa_key.pub
The key fingerprint is:
SHA256:[REMOVED BY ME] root@server.host.de
The key's randomart image is:
+---[ECDSA 256]---+
| [REMOVED BY ME] |
+----[SHA256]-----+
[2024/11/12 16:30:50] [INFO] - Code: 0 Result: Generating public/private rsa key pair.
Your identification has been saved in /etc/proftpd/ssh_host_rsa_key
Your public key has been saved in /etc/proftpd/ssh_host_rsa_key.pub
+---[RSA 3072]----+
| [REMOVED BY ME] |
+----[SHA256]-----+
[2024/11/12 16:30:51] [INFO] - Succeeded
[2024/11/12 16:30:51] [INFO] - Configuring Procmail
[2024/11/12 16:30:51] [INFO] - Configuring Quotas
[2024/11/12 16:30:51] [WARN] - Non-fatal error
[2024/11/12 16:30:51] [INFO] - Configuring SASL
[2024/11/12 16:30:52] [INFO] - Code: 0 Result:
[2024/11/12 16:30:52] [INFO] - Code: 256 Result: adduser: The user `postfix' does not exist.
[2024/11/12 16:30:52] [INFO] - Code: 256 Result: touch: cannot touch '/etc/postfix/sasl/smtpd.conf': No such file or directory
Can anybody help me, please?
Best regards,
fuggi
