Hi All,
I would much appreciate ir if someone can help me. I have been having problems to enable my
webmin install to send email through other port other than port 25 (since my vps provider
has blocked that port).
I’ve been trying to change my postfix install to use port 465 or 587.
This is my postconf -n :
command_directory = /usr/sbin
config_directory = /etc/postfix
daemon_directory = /usr/libexec/postfix
debug_peer_level = 2
header_checks = regexp:/etc/postfix/header_checks
home_mailbox = Maildir/
html_directory = no
inet_interfaces = all
local_destination_concurrency_limit = 5
local_destination_recipient_limit = 300
mail_owner = postfix
mailbox_command = /usr/bin/procmail
mailbox_transport = lmtp:unix:/var/lib/imap/socket/lmtp
mailq_path = /usr/bin/mailq.postfix
manpage_directory = /usr/share/man
message_size_limit = 4240000
mime_header_checks = pcre:/etc/postfix/body_checks
mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain
mydomain = indoku.co.id
myhostname = mail.indoku.co.id
mynetworks = 127.0.0.0/8
mynetworks_style = host
myorigin = $mydomain
newaliases_path = /usr/bin/newaliases.postfix
queue_directory = /var/spool/postfix
readme_directory = /usr/share/doc/postfix-2.3.3/README_FILES
recipient_delimiter = +
sample_directory = /usr/share/doc/postfix-2.3.3/samples
sendmail_path = /usr/sbin/sendmail.postfix
setgid_group = postdrop
smtp_sasl_auth_enable = yes
smtp_sasl_password_maps = /etc/postfix/sasl/smtp.conf
smtp_tls_note_starttls_offer = yes
smtp_use_tls = yes
smtpd_banner = $myhostname
smtpd_client_restrictions = permit_mynetworks reject permit_inet_interfaces
smtpd_helo_required = no smtpd_client_restrictions = permit_mynetworks, reject smtpd_helo_restrictions = reject_unknown_helo_hostname smtpd_sender_restrictions = reject_unknown_sender_domain smtpd_relay_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, reject_unauth_destination reject_rbl_client zen.spamhaus.org, reject_rhsbl_helo dbl.spamhaus.org, reject_rhsbl_sender dbl.spamhaus.org smtpd_data_restrictions = reject_unauth_pipelining
smtpd_recipient_restrictions = permit_mynetworks permit_sasl_authenticated # reject_unauth_destination is not needed here if the mail # relay policy is specified under smtpd_relay_restrictions # (available with Postfix 2.10 and later). reject_unauth_destination reject_rbl_client zen.spamhaus.org reject_rhsbl_helo dbl.spamhaus.org reject_rhsbl_sender dbl.spamhaus.org # Block clients that speak too early. smtpd_data_restrictions = reject_unauth_pipelining
smtpd_reject_unlisted_recipient = yes
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain =
smtpd_sasl_security_options = noanonymous noplaintext
smtpd_tls_auth_only = yes
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
smtpd_use_tls = yes
soft_bounce = no
tls_random_source = dev:/dev/urandom
unknown_local_recipient_reject_code = 550
[root@indoku ~]#
My master.cf :
Postfix master process configuration file. For details on the format
of the file, see the master(5) manual page (command: “man 5 master”).
service type private unpriv chroot wakeup maxproc command + args
(yes) (yes) (yes) (never) (100)
smtp inet n - n - - smtpd
smtps inet n - n - - smtpd
-o smtpd_sasl_auth_enable=yes
-o smtpd_reject_unlisted_sender=yes
-o smtpd_recipient_restrictions=permit_sasl_authenticated,reject
-o broken_sasl_auth_clients=yes
#submission inet n - n - - smtpd
-o smtpd_enforce_tls=yes
-o smtpd_client_restrictions=permit_sasl_authenticated,reject
#smtps inet n - n - - smtpd
-o smtpd_tls_wrappermode=yes
#628 inet n - n - - qmqpd
pickup fifo n - n 60 1 pickup
cleanup unix n - n - 0 cleanup
qmgr fifo n - n 300 1 qmgr
#qmgr fifo n - n 300 1 oqmgr
tlsmgr unix - - n 1000? 1 tlsmgr
rewrite unix - - n - - trivial-rewrite
bounce unix - - n - 0 bounce
defer unix - - n - 0 bounce
trace unix - - n - 0 bounce
verify unix - - n - 1 verify
flush unix n - n 1000? 0 flush
proxymap unix - - n - - proxymap
smtp unix - - n - - smtp
When relaying mail as backup MX, disable fallback_relay to avoid MX loops
relay unix - - n - - smtp
-o fallback_relay=
-o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - n - - showq
error unix - - n - - error
retry unix - - n - - error
discard unix - - n - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - n - - lmtp
anvil unix - - n - 1 anvil
scache unix - - n - 1 scache
Interfaces to non-Postfix software. Be sure to examine the manual
pages of the non-Postfix software to find out what options it wants.
Many of the following services use the Postfix pipe(8) delivery
agent. See the pipe(8) man page for information about ${recipient}
and other message envelope options.
maildrop. See the Postfix MAILDROP_README file for details.
Also specify in main.cf: maildrop_destination_recipient_limit=1
#maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/local/bin/maildrop -d ${recipient}
The Cyrus deliver program has changed incompatibly, multiple times.
#old-cyrus unix - n n - - pipe
flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
Cyrus 2.1.5 (Amos Gouaux)
Also specify in main.cf: cyrus_destination_recipient_limit=1
user=_cyrus argv=/usr/bin/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
See the Postfix UUCP_README file for configuration details.
#uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
Other external delivery methods.
#ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
#bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/local/sbin/bsmtp -f $sender $nexthop $recipient
#scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store
${nexthop} ${user} ${extension}
#mailman unix - n n - - pipe
flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
${nexthop} ${user}
My Maillog :
fatal: open dictionary: expecting “type:name” form instead of "/etc/postfix/sasl/smtp.confNov 24 13:29:30 indoku postfix/postfix-script[11532]: refreshing t$
Nov 24 13:29:30 indoku postfix/master[3685]: reload – version 2.6.6, configuration /etc/postfix
Nov 24 13:29:30 indoku postfix/qmgr[11537]: 3715426D095B: from=mark@indoku.co.id, size=455, nrcpt=1 (queue active)
Nov 24 13:29:30 indoku postfix/smtp[11539]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:29:31 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11539 exit status 1
Nov 24 13:29:31 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:30:31 indoku postfix/smtp[11645]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:30:32 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11645 exit status 1
Nov 24 13:30:32 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:31:32 indoku postfix/smtp[11660]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:31:33 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11660 exit status 1
Nov 24 13:31:33 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:32:33 indoku postfix/smtp[11693]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:32:34 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11693 exit status 1
Nov 24 13:32:34 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:33:34 indoku postfix/smtp[11709]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:33:35 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11709 exit status 1
Nov 24 13:33:35 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:34:35 indoku postfix/smtp[11735]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:34:36 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11735 exit status 1
Nov 24 13:34:36 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:35:36 indoku postfix/smtp[11839]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:35:37 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11839 exit status 1
Nov 24 13:35:37 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:36:37 indoku postfix/smtp[11852]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:36:38 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11852 exit status 1
Nov 24 13:36:38 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:37:39 indoku postfix/smtp[11884]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:37:40 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11884 exit status 1
Nov 24 13:37:40 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:38:40 indoku postfix/smtp[11897]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:38:41 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11897 exit status 1
Nov 24 13:38:41 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:39:41 indoku postfix/smtp[11910]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:39:42 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11910 exit status 1
Nov 24 13:39:42 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:40:42 indoku postfix/smtp[11992]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:40:43 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 11992 exit status 1
Nov 24 13:40:43 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:41:43 indoku postfix/smtp[12007]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:41:44 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 12007 exit status 1
Nov 24 13:41:44 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:42:44 indoku postfix/smtp[12020]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:42:45 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 12020 exit status 1
Nov 24 13:42:45 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:43:45 indoku postfix/smtp[12052]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:43:46 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 12052 exit status 1
Nov 24 13:43:46 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
Nov 24 13:44:46 indoku postfix/smtp[12065]: fatal: open dictionary: expecting “type:name” form instead of “/etc/postfix/sasl/smtp.conf”
Nov 24 13:44:47 indoku postfix/master[3685]: warning: process /usr/libexec/postfix/smtp pid 12065 exit status 1
Nov 24 13:44:47 indoku postfix/master[3685]: warning: /usr/libexec/postfix/smtp: bad command startup – throttling
If someone can help me make sense of the error. Please do… thanks.
I am trying to change postfix to use port 587 or 465 instead of port 25, since
my vps provider has blocked port 25.
Thank you.
