After clicking continue, nothing happens
What are the steps to start configuring for the first time?
Do you have enough of resources on your server?
If you choose No for the options on that page, can you go to the next step?
Do you see any errors on the browser’s console as clicking Next button?
I must say, I have never seen stuck post-configuration wizard in a way you do.
I’m using chrome and a translator plugin. when it is active it happens. when the page is displayed in the author’s language, everything is fine. problem solved. greetings
sob., 3 lip 2021, 12:45 użytkownik Ilia via Virtualmin Community <noreply@forum.virtualmin.com> napisał:
