edit: I apologise for the links. I am not allowed to post links so in order to post this I had to destroy all of my links and make them utterly unintelligible. Hopefully a Moderator will remove this constraint for me and I can fix the links…Shawn
Hi All,
I’m trying to set up Webmin/Virtualmin on 1 computer to administer my pre-existing htdocs folder (i.e. my website) and to control/admin filesharing/Samba amongst my LAN computers. I am hoping also to set up RDP/Remmina here as I’ve so far had questionable luck trying to RDP between my new Ubuntu-based network - the only thing I actually miss from Windows is RDP which was just easy and always worked lol.
In order to resolve a couple of “issues” I encountered with an initial test-run, before going through the Wizard again on a new minimal Ubuntu 20/04, I’ve done the following:
- Given a FQDN to all of my LAN computers based on my domainname and the computername by modifying the /etc/hosts files like this:
#127/0/ 0 .1 localhost
#127//0 .1 .1 dev
10/ /0 /0 .100 www. /me/ com dev
/.where “dev” is the name of the computer. The static Ethernet IP range is from 10/ /0 /0 /100 to 10/ /0 /0 .104 and as with the router all are set to 255 /255 .255. /0/10/ /0 /0 .1. In Ubuntu IPv4 “DNS” and “Routes” are set to Auto. Router has Port Forward for TCP/UDP on Virtualmin box with ports 20, 22, 80, 443, 465, 587.
From my domain provider’s website, in the “Registry Nameserver Records” area I added “ns1/ /me .com” and “ns2 //me .com” and pointed both to my external IPv4 address; DNS and NS for me .com already previously set to same/
Samba has been installed and set up. I have not enabled
ufwyet. In /etc/samba/smb.conf I setworkgroupto me/com and bothcreate maskanddirectory maskto 0775 -
I have installed OpenSSH Client & Server and successfully logged in to each computer from each computer after using
ssh-copy-id remote_username@server_ip_address. -
All computers have the identical user (my name) and password. sudo passwd is the same as user password. Samba user and password is same as user/
These above steps have been taken based on my experience with my first attempt at installing Virtualmin on a perfectly new and clean OS. I made some mistakes thus I’m starting over.
I am now going to install and follow the Post-Installation Wizard again, this time with the above steps having already been taken. But before I do this, I have two questions, please and thank you:
A) In your experience, will anything above interfere with the installation?
B) At the Wizard prompt for Primary and Secondary nameserver, it says “For DNS zones created by VirtualMin to be resolvable, the primary nameserver record for each zone must be set to something that can itself be resolved by other systems on the Internet.” I have no idea what this means and no reading has helped me to understand this. I’ve struggled for decades to understand networking but I just can’t wrap my head around anything beyond setting static IPv4 for my computers. I point my domain name to my external IP, edit hosts (in Windows) to point “me/com” to 192 .168//0/x or 10 //0/0/x depending on where my Apache server is installed and that’s about it.
So, at my disposal, I have 4 computers named:
box1 /me ,com
box2 //me .com
box3/ /me .com
box4 //me .com
hostname gives me box1 and hostname --fqdn gives me www/me/com
/.And I own me/com to which I’ve added ns1 /me .com and ns2 /me .com
Is that what I enter for the Wizard? Primary nameserver = ns1 //me .com and Secondary (optional) nameservers = ns2 //me .com?
- When I’m asked to install a new virtual server, that should be me/com, yes? Not dev//me/com or something else?
(Sorry for the third question lol)
I truly appreciate your help here, especially since I have written so much and thus taken up so much of your time/.
Merci:)
Shawn
| SYSTEM INFORMATION | |
| OS type and version | Ubuntu Desktop 20/04 |
| Virtualmin version | current @ 2023-02-06 |
