Port 10000 not opening no webmin is /etc/init.d
OS type and version CentOS7
Webmin version 1.994
I can get into usermin, but webin isn’t listed and the port doesn’t show 10000 as listening. Package webmin-1.994-1.noarch already installed and latest version. Nothing to do.
[root@vm4 webmin]# cd /etc
[root@vm4 etc]# cd init.d
[root@vm4 init.d]# dir
README  functions  install.sh  jailkit  lookup-domain  netconsole  network  usermin
[root@vm4 ~]# sudo lsof -i -P -n | grep LISTEN
sshd       720    root    3u  IPv4 1926315686      0t0  TCP *:22 (LISTEN)
sshd       720    root    4u  IPv6 1926315688      0t0  TCP *:22 (LISTEN)
httpd      721    root    4u  IPv6 1926312836      0t0  TCP *:80 (LISTEN)
httpd      721    root    6u  IPv6 1926312844      0t0  TCP *:443 (LISTEN)
dovecot    826    root   25u  IPv4 1926319308      0t0  TCP *:110 (LISTEN)
dovecot    826    root   26u  IPv6 1926319309      0t0  TCP *:110 (LISTEN)
dovecot    826    root   27u  IPv4 1926319310      0t0  TCP *:995 (LISTEN)
dovecot    826    root   28u  IPv6 1926319311      0t0  TCP *:995 (LISTEN)
dovecot    826    root   39u  IPv4 1926319332      0t0  TCP *:143 (LISTEN)
dovecot    826    root   40u  IPv6 1926319333      0t0  TCP *:143 (LISTEN)
dovecot    826    root   41u  IPv4 1926319334      0t0  TCP *:993 (LISTEN)
dovecot    826    root   42u  IPv6 1926319335      0t0  TCP *:993 (LISTEN)
miniserv.  942    root    4u  IPv4 1926320344      0t0  TCP *:20000 (LISTEN)
httpd      951  apache    4u  IPv6 1926312836      0t0  TCP *:80 (LISTEN)
httpd      951  apache    6u  IPv6 1926312844      0t0  TCP *:443 (LISTEN)
mysqld     989   mysql   18u  IPv4 1926330651      0t0  TCP *:3306 (LISTEN)
master    1041    root   13u  IPv4 1926322381      0t0  TCP 10.0.32.110:25 (LIST        EN)
master    1041    root   88u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LIS        TEN)
master    1041    root   91u  IPv4 1926322460      0t0  TCP 127.0.0.1:25 (LISTEN        )
master    1041    root   94u  IPv4 1926322464      0t0  TCP 10.0.32.113:587 (LIS        TEN)
master    1041    root   97u  IPv4 1926322468      0t0  TCP 127.0.0.1:587 (LISTE        N)
master    1041    root  100u  IPv4 1926322472      0t0  TCP 10.0.32.112:25 (LIST        EN)
master    1041    root  103u  IPv4 1926322476      0t0  TCP 10.0.32.112:587 (LIS        TEN)
master    1041    root  106u  IPv4 1926322480      0t0  TCP 10.0.32.113:25 (LIST        EN)
master    1041    root  109u  IPv4 1926322484      0t0  TCP 10.0.32.111:587 (LIS        TEN)
master    1041    root  112u  IPv4 1926322488      0t0  TCP 10.0.32.111:465 (LIS        TEN)
master    1041    root  115u  IPv4 1926322492      0t0  TCP 127.0.0.1:465 (LISTE        N)
master    1041    root  118u  IPv4 1926322496      0t0  TCP 10.0.32.110:465 (LIS        TEN)
/usr/libe 1052    root    3u  IPv4 1926323262      0t0  TCP 127.0.0.1:11000 (LIS        TEN)
proftpd   1077  nobody    0u  IPv6 1926335524      0t0  TCP *:21 (LISTEN)
proftpd   1077  nobody    1u  IPv6 1926335525      0t0  TCP *:2222 (LISTEN)
smtpd     1081 postfix    6u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LIS        TEN)
smtpd     1089 postfix    6u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LIS        TEN)
smtpd     1092 postfix    6u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LIS        TEN)
smtpd     1093 postfix    6u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LIS        TEN)
httpd     1099  apache    4u  IPv6 1926312836      0t0  TCP *:80 (LISTEN)
httpd     1099  apache    6u  IPv6 1926312844      0t0  TCP *:443 (LISTEN)
httpd     1104  apache    4u  IPv6 1926312836      0t0  TCP *:80 (LISTEN)
httpd     1104  apache    6u  IPv6 1926312844      0t0  TCP *:443 (LISTEN)
httpd     1108  apache    4u  IPv6 1926312836      0t0  TCP *:80 (LISTEN)
httpd     1108  apache    6u  IPv6 1926312844      0t0  TCP *:443 (LISTEN)
httpd     1114  apache    4u  IPv6 1926312836      0t0  TCP *:80 (LISTEN)
httpd     1114  apache    6u  IPv6 1926312844      0t0  TCP *:443 (LISTEN)
smtpd     1144 postfix    6u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LIS        TEN)
httpd     1262  apache    4u  IPv6 1926312836      0t0  TCP *:80 (LISTEN)
httpd     1262  apache    6u  IPv6 1926312844      0t0  TCP *:443 (LISTEN)
master    1041    root   13u  IPv4 1926322381      0t0  TCP 10.0.32.110:25 (LISTEN)
master    1041    root   88u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LISTEN)
master    1041    root   91u  IPv4 1926322460      0t0  TCP 127.0.0.1:25 (LISTEN)
master    1041    root   94u  IPv4 1926322464      0t0  TCP 10.0.32.113:587 (LISTEN)
master    1041    root   97u  IPv4 1926322468      0t0  TCP 127.0.0.1:587 (LISTEN)
master    1041    root  100u  IPv4 1926322472      0t0  TCP 10.0.32.112:25 (LISTEN)
master    1041    root  103u  IPv4 1926322476      0t0  TCP 10.0.32.112:587 (LISTEN)
master    1041    root  106u  IPv4 1926322480      0t0  TCP 10.0.32.113:25 (LISTEN)
master    1041    root  109u  IPv4 1926322484      0t0  TCP 10.0.32.111:587 (LISTEN)
master    1041    root  112u  IPv4 1926322488      0t0  TCP 10.0.32.111:465 (LISTEN)
master    1041    root  115u  IPv4 1926322492      0t0  TCP 127.0.0.1:465 (LISTEN)
master    1041    root  118u  IPv4 1926322496      0t0  TCP 10.0.32.110:465 (LISTEN)
/usr/libe 1052    root    3u  IPv4 1926323262      0t0  TCP 127.0.0.1:11000 (LISTEN)
smtpd     1081 postfix    6u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LISTEN)
smtpd     1089 postfix    6u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LISTEN)
smtpd     1092 postfix    6u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LISTEN)
smtpd     1093 postfix    6u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LISTEN)
smtpd     1144 postfix    6u  IPv4 1926322456      0t0  TCP 10.0.32.110:587 (LISTEN)
I resolved this
The latest versions of Webmin are using systemd unit service file. There is no longer /etc/init.d/webmin file available on systemd systems, which CentOS 7 is.
