How do I point a group of domains to the same directory? Obviously that’d be accomplished with a template but how exactly?
memox wrote:
One way to do that would be to:
Create the directory by setting up a new Virtual Server using one of those domains (through "Create Virtual Server")
Setup all the other domains as "Aliases" of the domain you setup above – go into "Create Virtual Server", and choose "Alias of your_domain.com".
Have a good one,
I just create the domains normally and then use an htaccess file to redirect to the one domain.
for each server:
this will direct all www.domain.net and domain.net to www.domain.com
RewriteCond %{HTTP_HOST} ^domain.net$ [OR]
RewriteCond %{HTTP_HOST} ^www.domain.net$
RewriteRule ^/?(.*)$ http://www.domain.com/$1 [R=301,L]
for each server:
