I am the only person that will admin domains in my server. So i dont need to give phpmyadmin to customers etc. For security reasons, i dont want phpmyadmin reachable. I just want it works “inside” virtualmin.
I found http://hdgadgets.com/gadget/virtualmin-phpmyadmin
It seems its features are what i want :
Installs the latest stable version of phpMyAdmin securely inside Webmin.
Adjusts phpMyAdmin for the best experience from inside Virtualmin.
Integrates nicely with the Virtual Server administration context.
Serves phpMyAdmin internally from under Webmin/miniserv.pl.
Can you check it if its working ok and is it safe? or do you have better alternative? I checked Install Scripts section… but its basically giving phpmyadmin to customer so its not needed nor safe against brute force tries.
