Jfro
December 23, 2019, 10:14am
1
Only point you all to this one with a link
https://www.adminer.org/
hy is Adminer better than phpMyAdmin?
Replace phpMyAdmin with Adminer and you will get a tidier user interface, better support for MySQL features, higher performance and more securit
Discussion and howto are welcome in this TOPIC ofcourse.
I use this in cases where PHPmyadmin is not working or possible but DATABASE acces is possible.
( For Virtualmin install Adminer is much more simple to use , and have some customized for users… )
Then together with Directory protection where the files are , and also some other as ip or whatever in htaccess or vhosts
Ilia
December 24, 2019, 1:22pm
2
Why removing phpMyAdmin ? This wouldn’t be possible, as there are other users who would prefer using phpMyAdmin .
What we could do, possibly, is to add Adminer to Virtialmin/Install Scripts , right @Joe @Eric ?
Eric
December 24, 2019, 8:30pm
3
That looks like a simple looking script, so it’s a definitely possibility.
We usually wait to add Install Scripts until we have multiple requests for it.
So we’ll put this one out to the community – would anyone else like to see Adminer as a Virtualmin Install Script?
Jfro
December 24, 2019, 9:12pm
4
Sorry that "
replace"
was not my text but a quote from the website from adminer!
But while this is so simple it could be nice to have for some…
And also easy for some who want to use it , even without beeing in virtualmin, still if some of the possible options as customize / plugins / and security is in virtualmin for it would be nicer.
