Phpmyadmin on virtualmin don't load
ok, you’ll need to go back to 7.2
do you have another domain on server ?
as yuou can install it again there and try different settings
I can try to another virtual host, where can i install only phpmyadmin with php 5.6.40.
worth a try,
I’m not sure if I’m helping ;o)
I see this post, not sure if it helps either ?
Ok works!
I’ve installed in a subdomain phpmyadmin.mydomain.com where i’ve installed only the phpmyadmin and works.
:+1:
thats good, great idea trying that :o)
Maybe phpmyadmin doesn’t work installed in sub folder, i’m not sure about that.
I always use it in subfolder, so it should work.
I mean sub folder where in the main folder there’s another script like wordpress or other.
possible it’s to do with wordpress, I don’t use it. I have a system in the root folder and phpmyadmin in subfolder.
Maybe something with htaccess, but i’m ok with this solution where can i check all databases. :slight_smile:
I installed mine in a subfolder but in its own. I wouldn’t mix like that as I’m sure it was an htaccess issue.
I’ve the htaccess of wordpress in the main folder.
