I can install phpMyAdmin for an individual domain under /home/username/public_html/phpmyadmin and it works perfectly.
I tried to set it up as the “multi-user” method that the docs recommended, using aliases for the phpmyadmin directory under each Domain’s directory, but when trying to visit the aliased page, it just times out.
Perhaps I’ve got the alias syntax wrong in Webmin/Virtualmin but am not sure.
Does anyone have a quick step-by-step on how to do this, including the exact syntax needed for the directory (directories?) entry?
I actually solved the problem myself yesterday (yay, lol) and now all domains simply use the format http://www.(domain).(extension)/phpmyadmin and it works like a champ. They only see their own databases, as well. I also added the extra bits to the main Server Template so it will setup new Domains correctly. The only time-consuming step was adding the changes to the existing Domains, but they’re all set now, too.
I think I’m finally beginning to get the hang of all this!
I’m using Debian and installing phpmyadmin with apt-get and making a symlink link between /usr/share/phpmyadmin and /home/domain1/public_html/phpmyadmin.
Same with domain2, a symlink link between /usr/share/phpmyadmin and /home/domain2/public_html/phpmyadmin.
Then in Webmin -> Apache Webserver -> (Choose a Virtual Server)
Then, under "Create Per-Directory, Files or Location Options"
Type: Directory
Regexp?: Exact Match
Path: /home/phpmyadmin
Click the Create button. On the page that comes up (Per-Directory Options), make the settings for ALL the categories match those for /home/(account name)/public_html (from the previous page).
Then, back on the "Virtual Server Options" page, make an entry in Aliases and Redirects:
To: /home/phpmyadmin
