phpMyAdmin auto-login doesn't work
OS type and version Debian 12
Webmin version 2.641
Virtualmin version 8.1.0
Webserver version Apache 2.4.67
Hello, I have an issue that Manage in phpMyAdmin button at Edit Database doesn’t auto-login, it just opens new window with phpMyAdmin login page. Tried to reinstall app multiple times, also global use checkmark is marked as Yes during installation process.
I see the same thing.
Thanks for the heads-up!
Could you apply the following two patches and let me know if that solves the issue for you:
webmin patch https://github.com/virtualmin/virtualmin-gpl/commit/c18f880
webmin patch https://github.com/virtualmin/virtualmin-gpl/commit/3d7a8a7
I’m auto-logging in now, thanks for the quick fix.
Just had a look at the code, a comprehensive fix :smiley:
