PHP script execution mode on C8 - options?
hello -
i used to see the following server-config–>website options when configuring a VS on C6 & 7:
Run CGI scripts as domain owner?   (yes/no)
	Apache mod_php (run as apache user)
	CGI wrapper (run as virtual server owner)
	FCGID (run as virtual server owner)
now i am only seeing this, and its no longer an option, rather its a pre-selected option:
PHP script execution mode FPM (run as virtual server owner)
did the CGI wrapper option disappear as an option because of something C8 is doing?
i am thinking i may need to determine what are the possible issues i may run into by running everything fast-cgi, other than probably needing to restart php-fpm frequently.
both the C7 & C8 are running virtualmin 6.12.
Why!!! Why would you need to restart php-fpm frequently? I mean… just… why?!
PHP-FPM is actually wonderful, such as the HHVM machine, some of the best php performers out there.
PHP7.4 will probably outperform both from what I’ve seen, but heck, I have all my servers with php-fpm.
A killer feature that is missing from Virtualmin is an NGINX+Apache Setup, having the nginx on the frontend serving static contents (which is done with a great performance and less resource consumption) and having apache handling the rest on the background.
cPanel has a plugin for this called Engintron, most web panels already have this out of the box. I’m curious to see how long will it take for Virtualmin to make it available.
i have never used it (yet)… but i figure since apache needs to be restarted frequently perhaps maybe same with php-fpm - but please note that i am speaking from sheer ignorance.
Hi @edwardsmarkf, sorry for this comment but if you need to restart apache frequently there must be some serious configuration issues with that.
I had to make apache restart frequently once maybe around a couple of years ago because of a problem of php7 module and both mpm_worker OR mpm_event would cause memory leaks with a given application (I actually don’t recall all the exact details by now).
I solved it removing the mod_php from apache and using php-fpm with mpm_event fine tuned. I couldn’t rest until I had this issue fixed, because the sole thought of the need of a cron to restart apache caused me the chills (twice a day, every 12 hours).
So, I believe you have an underlying problem and you should address it first. PHP-FPM is awesome (until it is no more) and definitely you should not consider normal having to restart Apache frequently.
This is covered in the announcement of CentOS 8 support: Virtualmin install.sh support for CentOS 8
