Here is the PHP Info:
PHP Version 5.1.6
System Linux collaborationserver 2.6.18-53.1.21.el5 #1 SMP Tue May 20 09:35:07 EDT 2008 x86_64
Build Date Sep 20 2007 09:58:12
Configure Command ‘./configure’ ‘–build=x86_64-redhat-linux-gnu’ ‘–host=x86_64-redhat-linux-gnu’ ‘–target=x86_64-redhat-linux-gnu’ ‘–program-prefix=’ ‘–prefix=/usr’ ‘–exec-prefix=/usr’ ‘–bindir=/usr/bin’ ‘–sbindir=/usr/sbin’ ‘–sysconfdir=/etc’ ‘–datadir=/usr/share’ ‘–includedir=/usr/include’ ‘–libdir=/usr/lib64’ ‘–libexecdir=/usr/libexec’ ‘–localstatedir=/var’ ‘–sharedstatedir=/usr/com’ ‘–mandir=/usr/share/man’ ‘–infodir=/usr/share/info’ ‘–cache-file=…/config.cache’ ‘–with-libdir=lib64’ ‘–with-config-file-path=/etc’ ‘–with-config-file-scan-dir=/etc/php.d’ ‘–disable-debug’ ‘–with-pic’ ‘–disable-rpath’ ‘–without-pear’ ‘–with-bz2’ ‘–with-curl’ ‘–with-exec-dir=/usr/bin’ ‘–with-freetype-dir=/usr’ ‘–with-png-dir=/usr’ ‘–enable-gd-native-ttf’ ‘–without-gdbm’ ‘–with-gettext’ ‘–with-gmp’ ‘–with-iconv’ ‘–with-jpeg-dir=/usr’ ‘–with-openssl’ ‘–with-png’ ‘–with-pspell’ ‘–with-expat-dir=/usr’ ‘–with-pcre-regex=/usr’ ‘–with-zlib’ ‘–with-layout=GNU’ ‘–enable-exif’ ‘–enable-ftp’ ‘–enable-magic-quotes’ ‘–enable-sockets’ ‘–enable-sysvsem’ ‘–enable-sysvshm’ ‘–enable-sysvmsg’ ‘–enable-track-vars’ ‘–enable-trans-sid’ ‘–enable-yp’ ‘–enable-wddx’ ‘–with-kerberos’ ‘–enable-ucd-snmp-hack’ ‘–with-unixODBC=shared,/usr’ ‘–enable-memory-limit’ ‘–enable-shmop’ ‘–enable-calendar’ ‘–enable-dbx’ ‘–enable-dio’ ‘–with-mime-magic=/etc/httpd/conf/magic’ ‘–without-sqlite’ ‘–with-libxml-dir=/usr’ ‘–with-xml’ ‘–enable-force-cgi-redirect’ ‘–enable-pcntl’ ‘–with-imap=shared’ ‘–with-imap-ssl’ ‘–enable-mbstring=shared’ ‘–enable-mbstr-enc-trans’ ‘–enable-mbregex’ ‘–with-ncurses=shared’ ‘–with-gd=shared’ ‘–enable-bcmath=shared’ ‘–enable-dba=shared’ ‘–with-db4=/usr’ ‘–with-xmlrpc=shared’ ‘–with-ldap=shared’ ‘–with-mysql=shared,/usr’ ‘–with-mysqli=shared,/usr/bin/mysql_config’ ‘–enable-dom=shared’ ‘–with-dom-xslt=/usr’ ‘–with-dom-exslt=/usr’ ‘–with-pgsql=shared’ ‘–with-snmp=shared,/usr’ ‘–enable-soap=shared’ ‘–with-xsl=shared,/usr’ ‘–enable-xmlreader=shared’ ‘–enable-xmlwriter=shared’ ‘–enable-fastcgi’ ‘–enable-pdo=shared’ ‘–with-pdo-odbc=shared,unixODBC,/usr’ ‘–with-pdo-mysql=shared,/usr’ ‘–with-pdo-pgsql=shared,/usr’ ‘–with-pdo-sqlite=shared,/usr’
Server API CGI/FastCGI
Virtual Directory Support disabled
Configuration File (php.ini) Path /home/songvest/etc/php5/php.ini
Scan this dir for additional .ini files /etc/php.d
additional .ini files parsed /etc/php.d/dom.ini, /etc/php.d/gd.ini, /etc/php.d/imap.ini, /etc/php.d/ldap.ini, /etc/php.d/mbstring.ini, /etc/php.d/mysql.ini, /etc/php.d/mysqli.ini, /etc/php.d/odbc.ini, /etc/php.d/pdo.ini, /etc/php.d/pdo_mysql.ini, /etc/php.d/pdo_odbc.ini, /etc/php.d/pdo_pgsql.ini, /etc/php.d/pdo_sqlite.ini, /etc/php.d/pgsql.ini, /etc/php.d/snmp.ini, /etc/php.d/xmlreader.ini, /etc/php.d/xmlrpc.ini, /etc/php.d/xmlwriter.ini, /etc/php.d/xsl.ini
PHP API 20041225
PHP Extension 20050922
Zend Extension 220051025
Debug Build no
Thread Safety disabled
Zend Memory Manager enabled
IPv6 Support enabled
Registered PHP Streams php, file, http, ftp, compress.bzip2, compress.zlib, https, ftps
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, sslv3, sslv2, tls
Registered Stream Filters string.rot13, string.toupper, string.tolower, string.strip_tags, convert., consumed, convert.iconv., bzip2., zlib.
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.1.0, Copyright © 1998-2006 Zend Technologies
with the ionCube PHP Loader v3.1.33, Copyright © 2002-2007, by ionCube Ltd.
PHP Credits
Configuration
PHP Core
Directive Local Value Master Value
allow_call_time_pass_reference Off Off
allow_url_fopen On On
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions no value no value
display_errors Off Off
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl On On
error_append_string no value no value
error_log syslog syslog
error_prepend_string no value no value
error_reporting 2047 2047
expose_php On On
extension_dir /usr/lib64/php/modules /usr/lib64/php/modules
file_uploads On On
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .:.:/php/includes:/usr/share/pear .:.:/php/includes:/usr/share/pear
log_errors On On
log_errors_max_len 1024 1024
magic_quotes_gpc Off Off
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
mail.force_extra_parameters no value no value
max_execution_time 30 30
max_input_nesting_level 64 64
max_input_time 60 60
memory_limit 16M 16M
open_basedir no value no value
output_buffering 4096 4096
output_handler no value no value
post_max_size 8M 8M
precision 14 14
realpath_cache_size 16K 16K
realpath_cache_ttl 120 120
register_argc_argv Off Off
register_globals Off Off
register_long_arrays Off Off
report_memleaks On On
report_zend_debug On On
safe_mode Off Off
safe_mode_exec_dir /usr/bin /usr/bin
safe_mode_gid Off Off
safe_mode_include_dir no value no value
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision 100 100
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 2M 2M
upload_tmp_dir no value no value
user_dir no value no value
variables_order EGPCS EGPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On On
zend.ze1_compatibility_mode Off Off
bz2
BZip2 Support Enabled
Stream Wrapper support compress.bz2://
Stream Filter support bzip2.decompress, bzip2.compress
BZip2 Version 1.0.3, 15-Feb-2005
calendar
Calendar support enabled
ctype
ctype functions enabled
curl
CURL support enabled
CURL Information libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
date
date/time support enabled
Timezone Database Version 2006.1
Timezone Database internal
Default timezone America/New_York
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.583333 90.583333
date.sunset_zenith 90.583333 90.583333
date.timezone no value no value
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.6.26
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
exif
EXIF Support enabled
EXIF Version 1.4 $Id: exif.c,v 1.173.2.5 2006/04/10 18:23:24 helly Exp $
Supported EXIF Version 0220
Supported filetypes JPEG,TIFF
ftp
FTP support enabled
gd
GD Support enabled
GD Version bundled (2.0.28 compatible)
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.2.1
GIF Read Support enabled
GIF Create Support enabled
JPG Support enabled
PNG Support enabled
WBMP Support enabled
XBM Support enabled
gettext
GetText Support enabled
gmp
gmp support enabled
hash
hash support enabled
Hashing Engines md4 md5 sha1 sha256 sha384 sha512 ripemd128 ripemd160 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru gost adler32 crc32 crc32b haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.5
iconv.input_encoding ISO-8859-1 ISO-8859-1
iconv.internal_encoding ISO-8859-1 ISO-8859-1
iconv.output_encoding ISO-8859-1 ISO-8859-1
imap
IMAP c-Client Version 2004
SSL Support enabled
Kerberos Support enabled
ldap
LDAP Support enabled
RCS Version $Id: ldap.c,v 1.161.2.3 2006/01/01 12:50:08 sniper Exp $
Total Links 0/unlimited
API Version 3001
Vendor Name OpenLDAP
Vendor Version 20327
libxml
libXML support active
libXML Version 2.6.26
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) version 3.7.1
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
mbstring.detect_order no value no value
mbstring.encoding_translation Off Off
mbstring.func_overload 0 0
mbstring.http_input pass pass
mbstring.http_output pass pass
mbstring.internal_encoding no value no value
mbstring.language neutral neutral
mbstring.strict_detection Off Off
mbstring.substitute_character no value no value
mime_magic
mime_magic support enabled
mime_magic.debug Off Off
mime_magic.magicfile /etc/httpd/conf/magic /etc/httpd/conf/magic
mysql
MySQL Support enabled
Active Persistent Links 0
Active Links 0
Client API version 5.0.22
MYSQL_MODULE_TYPE external
MYSQL_SOCKET /var/lib/mysql/mysql.sock
MYSQL_INCLUDE -I/usr/include/mysql
MYSQL_LIBS -L/usr/lib64/mysql -lmysqlclient
mysql.allow_persistent On On
mysql.connect_timeout 60 60
mysql.default_host no value no value
mysql.default_password no value no value
mysql.default_port no value no value
mysql.default_socket no value no value
mysql.default_user no value no value
mysql.max_links Unlimited Unlimited
mysql.max_persistent Unlimited Unlimited
mysql.trace_mode Off Off
mysqli
MysqlI Support enabled
Client API library version 5.0.22
Client API header version 5.0.22
MYSQLI_SOCKET /var/lib/mysql/mysql.sock
mysqli.default_host no value no value
mysqli.default_port 3306 3306
mysqli.default_pw no value no value
mysqli.default_socket no value no value
mysqli.default_user no value no value
mysqli.max_links Unlimited Unlimited
mysqli.reconnect Off Off
odbc
ODBC Support enabled
Active Links 0
ODBC library unixODBC
ODBC_INCLUDE -I/usr/include
ODBC_LFLAGS -L/usr/lib64
ODBC_LIBS -lodbc
odbc.allow_persistent On On
odbc.check_persistent On On
odbc.default_db no value no value
odbc.default_pw no value no value
odbc.default_user no value no value
odbc.defaultbinmode return as is return as is
odbc.defaultlrl return up to 4096 bytes return up to 4096 bytes
odbc.max_links Unlimited Unlimited
odbc.max_persistent Unlimited Unlimited
openssl
OpenSSL support enabled
OpenSSL Version OpenSSL 0.9.8b 04 May 2006
pcntl
pcntl support enabled
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 6.6 06-Feb-2006
PDO
PDO support enabled
PDO drivers mysql, odbc, pgsql, sqlite
pdo_mysql
PDO Driver for MySQL, client library version 5.0.22
PDO_ODBC
PDO Driver for ODBC (unixODBC) enabled
ODBC Connection Pooling Enabled, strict matching
pdo_pgsql
PDO Driver for PostgreSQL enabled
PostgreSQL(libpq) Version 8.1.9
Module version 1.0.2
Revision $Id: pdo_pgsql.c,v 1.7.2.11 2006/03/14 10:49:18 edink Exp $
pdo_sqlite
PDO Driver for SQLite 3.x enabled
PECL Module version 1.0.1 $Id: pdo_sqlite.c,v 1.10.2.6 2006/01/01 12:50:12 sniper Exp $
SQLite Library 3.3.6
pgsql
PostgreSQL Support enabled
Multibyte character support enabled
SSL support enabled
Active Links 0
pgsql.allow_persistent On On
pgsql.auto_reset_persistent Off Off
pgsql.ignore_notice Off Off
pgsql.log_notice Off Off
pgsql.max_links Unlimited Unlimited
pgsql.max_persistent Unlimited Unlimited
posix
Revision $Revision: 1.70.2.3 $
pspell
PSpell Support enabled
Reflection
Reflection enabled
Version $Id: php_reflection.c,v 1.164.2.33 2006/03/29 14:28:42 tony2001 Exp $
session
Session Support enabled
Registered save handlers files user
Registered serializer handlers php php_binary wddx
session.auto_start Off Off
session.bug_compat_42 Off Off
session.bug_compat_warn On On
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file no value no value
session.entropy_length 0 0
session.gc_divisor 1000 1000
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.hash_bits_per_character 5 5
session.hash_function 0 0
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /home/songvest/tmp /home/songvest/tmp
session.serialize_handler php php
session.use_cookies On On
session.use_only_cookies Off Off
session.use_trans_sid 0 0
shmop
shmop support enabled
SimpleXML
Simplexml support enabled
Revision $Revision: 1.151.2.22 $
Schema support enabled
snmp
NET-SNMP Support enabled
NET-SNMP Version 5.3.1
sockets
Sockets Support enabled
SPL
SPL support enabled
Interfaces Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, DirectoryIterator, DomainException, EmptyIterator, FilterIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RuntimeException, SimpleXMLIterator, SplFileInfo, SplFileObject, SplObjectStorage, SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Regex Library Bundled library enabled
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
url_rewriter.tags a=href,area=href,frame=src,input=src,form=fakeentry a=href,area=href,frame=src,input=src,form=fakeentry
user_agent no value no value
sysvmsg
sysvmsg support enabled
Revision $Revision: 1.20.2.3 $
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.6.26
xmlreader
XMLReader enabled
xmlrpc
core library version xmlrpc-epi v. 0.51
php extension version 0.51
author Dan Libby
homepage http://xmlrpc-epi.sourceforge.net
open sourced by Epinions.com
xmlwriter
XMLWriter enabled
xsl
XSL enabled
libxslt Version 1.1.17
libxslt compiled against libxml Version 2.6.26
EXSLT enabled
libexslt Version 1.1.17
zlib
ZLib Support enabled
Stream Wrapper support compress.zlib://
Stream Filter support zlib.inflate, zlib.deflate
Compiled Version 1.2.3
Linked Version 1.2.3
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
ionCube Loader
sysvsem
sysvshm
Environment
Variable Value
PHPRC /home/songvest/fcgi-bin/…/etc/php5
SCRIPT_FILENAME no value
PATH /usr/local/bin:/usr/bin:/bin
PWD /home/songvest/fcgi-bin
SHLVL 0
PHP Variables
Variable Value
_REQUEST["admin_classified_session"] 3d3ad32e22587ad133a03caca71e3330
_COOKIE["admin_classified_session"] 3d3ad32e22587ad133a03caca71e3330
_SERVER["FCGI_ROLE"] RESPONDER
_SERVER["PERL5LIB"] /usr/share/awstats/lib:/usr/share/awstats/plugins
_SERVER["HTTP_HOST"] 192.168.1.100
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9) Gecko/2008051206 Firefox/3.0
_SERVER["HTTP_ACCEPT"] text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8
_SERVER["HTTP_ACCEPT_LANGUAGE"] en-us,en;q=0.5
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate
_SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,;q=0.7
_SERVER["HTTP_KEEP_ALIVE"] 300
_SERVER["HTTP_CONNECTION"] keep-alive
_SERVER["HTTP_COOKIE"] admin_classified_session=3d3ad32e22587ad133a03caca71e3330
_SERVER["PATH"] /usr/local/bin:/usr/bin:/bin
_SERVER["SERVER_SIGNATURE"] <address>Apache/2.2.3 (CentOS) Server at 192.168.1.100 Port 80</address>
_SERVER["SERVER_SOFTWARE"] Apache/2.2.3 (CentOS)
_SERVER["SERVER_NAME"] 192.168.1.100
_SERVER["SERVER_ADDR"] 192.168.1.100
_SERVER["SERVER_PORT"] 80
_SERVER["REMOTE_ADDR"] 192.168.1.7
_SERVER["DOCUMENT_ROOT"] /home/songvest/public_html
_SERVER["SERVER_ADMIN"] root@localhost
_SERVER["SCRIPT_FILENAME"] no value
_SERVER["REMOTE_PORT"] 3746
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["SERVER_PROTOCOL"] HTTP/1.1
_SERVER["REQUEST_METHOD"] GET
_SERVER["QUERY_STRING"] no value
_SERVER["REQUEST_URI"] /showphp.php
_SERVER["SCRIPT_NAME"] /showphp.php
_SERVER["ORIG_SCRIPT_NAME"] /showphp.php
_SERVER["ORIG_SCRIPT_FILENAME"] /home/songvest/public_html/showphp.php
_SERVER["PATH_INFO"] no value
_SERVER["PATH_TRANSLATED"] no value
_SERVER["PHPRC"] /home/songvest/fcgi-bin/…/etc/php5
_SERVER["PWD"] /home/songvest/fcgi-bin
_SERVER["SHLVL"] 0
_SERVER["PHP_SELF"] /showphp.php
_SERVER["REQUEST_TIME"] 1212607869
_ENV["FCGI_ROLE"] RESPONDER
_ENV["PERL5LIB"] /usr/share/awstats/lib:/usr/share/awstats/plugins
_ENV["HTTP_HOST"] 192.168.1.100
_ENV["HTTP_USER_AGENT"] Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9) Gecko/2008051206 Firefox/3.0
_ENV["HTTP_ACCEPT"] text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8
_ENV["HTTP_ACCEPT_LANGUAGE"] en-us,en;q=0.5
_ENV["HTTP_ACCEPT_ENCODING"] gzip,deflate
_ENV["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,;q=0.7
_ENV["HTTP_KEEP_ALIVE"] 300
_ENV["HTTP_CONNECTION"] keep-alive
_ENV["HTTP_COOKIE"] admin_classified_session=3d3ad32e22587ad133a03caca71e3330
_ENV["PATH"] /usr/local/bin:/usr/bin:/bin
_ENV["SERVER_SIGNATURE"] <address>Apache/2.2.3 (CentOS) Server at 192.168.1.100 Port 80</address>
_ENV["SERVER_SOFTWARE"] Apache/2.2.3 (CentOS)
_ENV["SERVER_NAME"] 192.168.1.100
_ENV["SERVER_ADDR"] 192.168.1.100
_ENV["SERVER_PORT"] 80
_ENV["REMOTE_ADDR"] 192.168.1.7
_ENV["DOCUMENT_ROOT"] /home/songvest/public_html
_ENV["SERVER_ADMIN"] root@localhost
_ENV["SCRIPT_FILENAME"] no value
_ENV["REMOTE_PORT"] 3746
_ENV["GATEWAY_INTERFACE"] CGI/1.1
_ENV["SERVER_PROTOCOL"] HTTP/1.1
_ENV["REQUEST_METHOD"] GET
_ENV["QUERY_STRING"] no value
_ENV["REQUEST_URI"] /showphp.php
_ENV["SCRIPT_NAME"] /showphp.php
_ENV["ORIG_SCRIPT_NAME"] /showphp.php
_ENV["ORIG_SCRIPT_FILENAME"] /home/songvest/public_html/showphp.php
_ENV["PATH_INFO"] no value
_ENV["PATH_TRANSLATED"] no value
_ENV["PHPRC"] /home/songvest/fcgi-bin/…/etc/php5
_ENV["PWD"] /home/songvest/fcgi-bin
_ENV["SHLVL"] 0
_ENV["PHP_SELF"] /showphp.php
_ENV["REQUEST_TIME"] 1212607869
PHP License
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net.
