PHP from sury repository apt update problem
On Debian 11 I received a warning when apt upgrade:
Keys stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg) have been deprecated, see the DEPRECATION
section in apt-key(8) for details.  The /etc/apt/trusted.gpg.d/debsuryorg-archive.gpg file will be removed in
the next update of the package and you MUST update your APT sources to include
[signed-by=/usr/share/keyrings/debsuryorg-archive-keyring.gpg] directive. See the Debian Wiki for more
information: https://wiki.debian.org/DebianRepository/UseThirdParty#Sources.list_entry
To fix this I downloaded and saved the key to the new location:
curl -fsSL https://packages.sury.org/php/apt.gpg | sudo tee /usr/share/keyrings/debsuryorg-archive-keyring.gpg > /dev/null
And upgraded /etc/apt/sources.list.d/php.list to:
deb [signed-by=/usr/share/keyrings/debsuryorg-archive-keyring.gpg] https://packages.sury.org/php/ bullseye main
I think it fixed the issue. Problem is the online instructions still puts the key in the deprecated location thrusted.gpg.d
CONFIRMED! I did these same steps yesterday, online docs need update.
If you know exactly whats to be changed there is a “suggest change” link on the docs, then it will be looked at.
Please don’t post ChatGPT or other large language model output to the forum. It is against our guidelines, for a variety of reasons.
Done. Makes me nervous recommending changes to Virtualmin though
I got this message from webmin after my last update I think.
debsuryorg-archive-keyring (2025.03.11) unstable; urgency=medium
  • The /etc/apt/trusted.gpg.d/debsuryorg-archive.gpg global APT key will
    been removed in the next update of the package.
    The script will try to autodetect whether any APT repository is not
    configured with signed-by= directive and will print warning about the
    installation of this package.
    You need to manually add:
    to your APT sources lists. See the Debian Wiki for more information:
– Ondřej Surý ondrej@debian.org Tue, 11 Mar 2025 14:08:14 +0100
Hello ID10T, thank you for your information. I have received the same warning. How do I manually add [signed-by=/usr/share/keyrings/debsuryorg-archive-keyring.gpg] to my apt sources lists? And where? In the “/etc/apt/sources.list” file ? Or rather in “/etc/apt/sources.list.d”? And what exactly should the entry look like besides “[signed-by=/usr/share/keyrings/debsuryorg-archive-keyring.gpg]” ?
Perhaps you can define it in a few steps. Thank you for your time.
On my system:
/etc/apt/sources.list.d/sury-debian-php-bookworm.list
currently has the value: "deb https://packages.sury.org/php/ bookworm main"
change it to:
"deb [signed-by=/usr/share/keyrings/debsuryorg-archive-keyring.gpg] https://packages.sury.org/php/ bookworm main"
It this the way it should be done?
I took it literally except I did add it to the specific entry like you suggest. I have it on two lines. That said, if my updates fail, I break nothing of value and I have time to fix it.
Thank you. I did the same. Seems to be working. :slight_smile:
