Hi there,
Here are the server specifications:
- Operating system: CentOS Linux 7.4.1708
- Webmin version: 1.881
- Usermin version: 1.741
- Virtualmin version: 6.03
- Theme version: Authentic Theme 19.09.2
- Kernel and CPU: Linux 3.10.0-693.21.1.el7.x86_64 on x86_64
- Processor information: Virtual CPU 82d9ed4018dd, 4 cores
- System uptime: 4 days, 21 hours, 49 minutes
- Running processes: 337
- CPU load averages: 0.00 (1 min) 0.04 (5 mins) 0.05 (15 mins)
- Real memory: 5.60 GB used / 7.46 GB total
- Virtual memory: 27.59 MB used / 3.91 GB total
- Local disk space: 23.64 GB used / 74.80 GB free / 98.43 GB total
- I installed NGINX
- I installed PHP 7.2
- I update MariaDB to 10.2
- I installed REDIS and configured it to save PHP sessions
- I configured 4GB swap space with a swappiness of 30
Question:
Under the NGINX settings I see that “Connect Nginx to PHP processes with” is set to “Socket Files”. However, all servers that use PHP-FPM use IP based routing in their NGINX config, e.g. localhost:8000.
It works great, but I read that it is slightly slower than socket based routing, so I am wondering if it is possible to change it?
