perl execution failed
When trying to install Horde or squirrelmail via the install scripts option on my fresh Debian server I get the following error message:
HTTP/1.0 500 Perl execution failed Server: MiniServ/0.01 Date: Mon, 5 Nov 2007 21:35:52 GMT Content-type: text/html Connection: close
Error - Perl execution failed
Undefined subroutine &php_pear::get_pear_commands called at /usr/share/webmin/virtual-server/scripts-lib.pl line 764.
This happened after updating Pear to the required version (1.6.1).
Any suggestions on how to fix this?
Bueller…Bueller
Hey Kevin,
Looka likea bug.
Try 3.37. If it persists, file a bug and Jamie will get it fixed quick like.
That update fixed it…must have just came out as I just installed the latest yesterday…but that fixed it…THANKS!
Fixed it. Don’t know if it had something to do with it but it seems that installing Webmin module PHP-Pear-modules(v1.2) found in the repository did the trick…(?) Apparently my webmin was running version PHP-Pear-modules(v1.0)
Hi there
I just got the error below when trying to install horde…
[code:1]
Downloading ftp://ftp.horde.org/pub/horde/horde-3.1.5.tar.gz (5285660 bytes) …
Received 5285660 bytes (100 %)
… download complete.
HTTP/1.0 500 Perl execution failed Server: MiniServ/0.01 Date: Thu, 29 Nov 2007 00:12:46 GMT Content-type: text/html Connection: close
Undefined subroutine &php_pear::get_pear_commands called at /usr/libexec/webmin/virtual-server/scripts-lib.pl line 808.
[/code:1]
PEAR ver is 1.4.9
thanks for any help you can offer
l.
I’m a BIG ?
I think I have 3 pear’s installed.
I have under usr/lib/
php php4 php5
And under etc I have: php4 and php5 Everytime I run pear or pear4 I get this:
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/mcrypt.so' - /usr/lib/php4/mcrypt.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/gd.so' - /usr/lib/php4/gd.so: undefined symbol: empty_string in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/imap.so' - /usr/lib/php4/imap.so: undefined symbol: zend_hash_index_update_or_next_insert in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/ldap.so' - /usr/lib/php4/ldap.so: undefined symbol: empty_string in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/mbstring.so' - /usr/lib/php4/mbstring.so: undefined symbol: empty_string in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/mcrypt.so' - /usr/lib/php4/mcrypt.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/mysql.so' - /usr/lib/php4/mysql.so: undefined symbol: empty_string in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/mysqli.so' - /usr/lib/php4/mysqli.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/odbc.so' - /usr/lib/php4/odbc.so: undefined symbol: empty_string in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/pdo.so' - /usr/lib/php4/pdo.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/pdo_mysql.so' - /usr/lib/php4/pdo_mysql.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/pdo_odbc.so' - /usr/lib/php4/pdo_odbc.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/pdo_pgsql.so' - /usr/lib/php4/pdo_pgsql.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/pdo_sqlite.so' - /usr/lib/php4/pdo_sqlite.so: cannot open shared object file: No such file or directory in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/pgsql.so' - /usr/lib/php4/pgsql.so: undefined symbol: empty_string in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/snmp.so' - /usr/lib/php4/snmp.so: undefined symbol: _zval_dtor in Unknown on line 0 PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib/php4/xmlrpc.so' - /usr/lib/php4/xmlrpc.so: undefined symbol: zend_hash_index_update_or_next_insert in Unknown on line 0
I’m not sure when this began, but I can not upgrade Horde.
It seems my pear is f***ed up, and I have no clue how to fix it.
Peter
