I’m running Virtualmin GPL on a Debian 7 VPS, set up from install.sh and working well for almost a year now. I’m encountering a problem for the first time I think, because the circumstance simply hasn’t arisen until now.
I have a real SSL certificate for my server’s actual hostname for use in Webmin, Dovecot, Postfix, etc. This is completely functional ATM.
I now need to also have a different certificate for one of my hosted domains’ webmin login, so that people do not receive an SSL warning when visiting either https://my.servername.com:10000 or https://client.hostedname.com:10000
Thus far I have only managed to make one or the other work. Is there a way to configure Webmin to use a different certificate per login domain?
Edit: I should probably clarify, I’m only using a single IP address, which hasn’t been an issue for Apache so far thanks to SNI.
