SYSTEM INFORMATION | |
OS type and version | Ubuntu 20.04 |
Webmin version | 1.994 |
Virtualmin version | 7.1-1 Pro |
Related packages | Cloudmin/Virtualmin |
Hi there. We bought a Cloudmin Pro license to use the Virtualmin Domain replicaction feature. We added our second host as a physical system. We receive the following error:
Failed to restore on : Unknown --virtualmin option styles. Available options are : config templates resellers email custom scripts scheds chroot mailserver
We are temporarily using the same virtualmin license on both servers. It’s only been a few days though as it says it’s ok if we just migrating - we can use the same license temporarily on two servers. Do we need a seperate license for both servers for this to work or is something else the issue?
We already tried disabling all global settings and it still didn’t work, unfortunately. Both servers are the latest version of webmin/virtualmin/cloudmin.
Thanks!
