I am trying to host virtualmin mails in an external drive that I can reach with WebDAV. I need a good solution for this. Willing to pay for a proper guide
here is some tips for external storage settings. I couldnt find whole solution tho…
https://doc.dovecot.org/configuration_manual/nfs/
I can’t help, but some pointers for whoever can:
Dovecot retrieves mail on behalf of clients. Procmail delivers it to mailboxes. You’ll need to be able to mount your remote drive as a filesystem that is accessible to both. I believe you’d use davfs2 for that (but maybe there are other options now, I am not familiar with the area): WebDAV Linux File System (davfs2)
The Dovecot docs you’ve linked cover NFS; WebDAV is a quite different protocol. It may have some of the same potential issues, but it’s not the same, or even similar, protocol (and while it is a more modern protocol, it’s also very quirky in its own right).
I created a job here:
https://www.upwork.com/ab/applicants/1524665571429240832/job-details
I closed the job.
For future reference;
I decided switching to dedicated server from cloud and will use onlyoffice docker version.
Thanks for your time.
