Guys, I’ve been going around in circles trying to add a Hostname and SSL cert in new install. For some strange reason Let’s keeps denying because of a 404 error. When trying to call the domain, I get Page Not Found, even though there’s an index.html page in the directory. Before I delete server and start over, would someone please direct me in the right direction?. Thanks…
Plugins selected: Authenticator webroot, Installer None
Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for ns1.intrelligentconnect.com
Using the webroot path /home/intrelligentconnect/domains/ns1.intrelligentconnect.com/public_html for all unmatched domains.
Waiting for verification…
Challenge failed for domain ns1.intrelligentconnect.com
Cleaning up challenges
Some challenges have failed.
IMPORTANT NOTES:
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address.
Ty Rich. I got it working. I was using port 80 for another app. I removed it and now it works, however, I changed the ports and now I’m locked out. The Panel will not display. Any idea?..Now it’s 12 hrs spent on this ordeal…
I’d try clearing the browser cache and temp files, especially if you’re using Chrome. The problem may be in your browser. If that doesn’t do it, I’d try restarting Apache.
I’ve tried that several times. I’ve changed computers as well. I put Port 22 back and nothing… It’s there a way to change VM listening port back to 10000?.. Please advice. I can’t delete and start this server again… TY
All you should have to do to get panel access back is change the port entry in the first line back to 10000, restart webmin, make the firewall and SELinux edits, and restart firewalld.
