I found this file on http://www.awstats.org/. I know Webmin comes with its own module for AWstats but I installed it. This module creates in Webmin -> System the following link: AWStats Logfile Analyzer.
In module configuration you have to do some changes then [Save]:
Absolute filesystem path to AWStats update statistics command:
/usr/lib/cgi-bin/awstats.pl -
Sample AWStats configuration file
/etc/awstats/awstats.conf.local (I guess this should be the one ??)
I would like to ask if step 2 is correct and if you use this module? What is your opinion about this module? As I see it offers a few more options and it could be part of Webmin.
Thank you.
