Juanka
March 10, 2024, 5:05pm
1
OS type and version
Ubuntu Linux 22.04.4
Virtualmin version
7.9.0
I’m having problems configuring a smtp plugin for email, the problem I’m having is attached in this message.
Would anyone know how to fix it?
Thanks and best regards.
Works fine for me, did you use these setting (if your using virtualmin settings)
Juanka
March 11, 2024, 10:03am
3
Yes, of course I have it set up correctly.
What version of wordpress are you using? I’m using the latest 6.4.3.
Try using the latest version of wordpress and see if you still get the error.
Not sure why you said
How do I know that, I don’t know what you did from the your first post.
If you set it up correctly then I don’t why you are having issue as it works fine for me.
Good luck in solving your issue.
BTW, I’m use the latest versions of everything “of cause”.
system
Closed
May 10, 2024, 10:35am
5
