OpenProject with virtualmin
Hello.
I have recently installed OP.Everthing is ok except, when asking to install apache2. I did skip because apache is already installed by virtualmin.
When i did this command i get this
root@projectok:/home/server# sudo openproject run check
[ok] PostgreSQL configuration is working
[ko] Web server is NOT running
[ok] openproject server is running
[ok] openproject background job worker is running
sending test email using SMTP…
7: from /opt/openproject/packaging/scripts/send-test-email:39:in <main>' 6: from /opt/openproject/vendor/ruby-2.7.5/lib/ruby/2.7.0/net/smtp.rb:524:in start’
5: from /opt/openproject/vendor/ruby-2.7.5/lib/ruby/2.7.0/net/smtp.rb:548:in do_start' 4: from /opt/openproject/vendor/ruby-2.7.5/lib/ruby/2.7.0/timeout.rb:105:in timeout’
3: from /opt/openproject/vendor/ruby-2.7.5/lib/ruby/2.7.0/net/smtp.rb:549:in block in do_start' 2: from /opt/openproject/vendor/ruby-2.7.5/lib/ruby/2.7.0/net/smtp.rb:539:in tcp_socket’
1: from /opt/openproject/vendor/ruby-2.7.5/lib/ruby/2.7.0/net/smtp.rb:539:in open' /opt/openproject/vendor/ruby-2.7.5/lib/ruby/2.7.0/net/smtp.rb:539:in initialize’: execution expired (Net::OpenTimeout)
[ko] unable to send test email to anujchadha@anujchadha.gq
Now i am starting configure apache2 (virtualmin) with OP. So i did this anujchadha.gq.conf but my actual vhost file is this anujchadha.gq.conf bk. the problem is i cant access OP Web page.Please help me with apache2 vhost file. I have more website too
anujchadha.gq.conf (2.7 KB)
addressbook.gq.conf (4.9 KB)
@anuj9122,
To be honest, from looking at the OpenProject website it looks like it’d be best to install this on a dedicated system without Virtualmin, similar to that of Discourse and other products which seem to require a certain configuration for products that Virtualmin also provides. It also seems as if it’d likely benefit from dedicated resources as well. Virtualmin is best used for “shared hosting” where you’re running more simple web apps.
