Hi I’ve been trying to set up an Opencart multi-store without success, can anyone please help me to get it working?
The concept sounds easy enough in their guide here: Multi-Store - OpenCart Documentation
But doing this on Virtualmin doesn’t work for me.
I’ve installed opencart on a subdomain like this: shop1.domain.com
Then I’ve created another subdomain at shop2.domain.com
and found its /etc/apache2/sites-available/shop2.domain.com config file.
Then I set the DocumentRoot as /home/domain.com/domains/shop1.domain.com/public_html
so that they share the same public_html folder.
Then in my Opencart shop admin area for shop1 I’ve added shop2.domain.com as a second store in the Opencart settings.
This kinda almost works. If i navigate to https://store2.domain.com
Then it redirects itself to www.store2.domain and does actually show the shop (albeit unsecure and not using the ssl I’ve set up.
If I navigate to shop1.domain.com then that shows up fine and works with SSL etc.
But the problem is it only sort of appears to work, as when I visit shop2.domain.com the title in the browser is for shop1 and all the products shown are shop1’s - so it’s just sort of working like an alias and not a different shop.
Reading on the forums it seems some users have managed to get this to work, but there are no current threads open that I can ask how they got it working.
can anyone please help? Thanks very much.
