one dedicated server(centos/apache) hosts multi virtual servers, but all are led to first domain
I hope to host multi virtual servers on one dedicated server.
their domain are a.com b.com c.com which use same ip.
DocumentRoot at
/home/a/public_html
/home/b/public_html
/home/c/public_html
ftp root
/home/a/
/home/b/
/home/c/
below are what I did
  1. in virtualmin, create virtual server named a.com b.com c.com
  2. edit httpd.conf
vi /etc/httpd/conf/httpd.conf
< virtualHost *:80 >
DocumentRoot /home/a/public_html/
ServerName  *.a.com
ServerAlias *.a.com
ServerAlias a.com
< /VirtualHost >
DocumentRoot /home/b/public_html/
ServerName *.b.com
ServerAlias *.b.com
ServerAlias b.com
< /VirtualHost >
DocumentRoot /home/c/public_html/
ServerName *.c.com
ServerAlias *.c.com
ServerAlias c.com
< /VirtualHost >
3.restart apache, it display
[warn] default VirtualHost overlap on port 80, the first has precedence
but when I input a.com b.com c.com in web browser,
all are led to a.com rather than a.com b.com c.com
Your comment welcome
Try using the IP address instead of “*” in the VirtualHost directives. Apache has some quite complex rules when determining which virtual host to serve, and it’s best to be as specific as possible in VirtualHost. That’s what Virtualmin does too by default, and correctly; how come you had to edit http.conf at all?
[warn] VirtualHost 50.23.16.18:80 overlaps with VirtualHost 50.23.16.18:80, the first has precedence, perhaps you need a NameVirtualHost directive
I do not what does this mean
I checked http.conf
DocumentRoot is /var/html
and not virtual host site info
I created the virtual servers in VirtualMin.
and check the http.conf
it did not change the DocumentRoot and add the virtual host info, so I added.
just wonder
if
name-based virtual host
http://httpd.apache.org/docs/2.4/vhosts/name-based.html
and virtual server are same thing?
Virtualmin doesn’t put the new servers into the main httpd.conf file, but in the sites-available subfolder.
[root@server1 home]# cd /etc/apache2/sites-available/
-bash: cd: /etc/apache2/sites-available/: No such file or directory
even I changed
virtualHost *:80
to
virtualHost 1.2.3.4:80 (1.2.3.4 is actual ip)
very thing is same.
All access for a.com b.com c.com are led to a.com
You should try recreating the virtual servers, and not mess with the httpd config. :slight_smile: Virtualmin normally does this all okay, and if it doesn’t for you, there’s something else wrong.
If you delete and re-create the servers, and don’t edit the config, what’s the exact problem?
Hi Locutus!
Note that on CentOS, it actually does add the entries to the httpd.conf file.
Virtualmin tries to “go with the flow” regarding how a given distribution works… both Debian and Ubuntu use the /etc/apache2/sites-available/ dirs, with individual .conf files.
On CentOS, each individual VirtualHost entry is added to the end of the httpd.conf file, as CentOS doesn’t use the sites-available directory (even though I kind of which it would!)
I removed all virtual sites , remove apache and reinstall virtualmin
yum -y remove httpd
yum -y install file
yum -y install patch
yum -y update
wget http://software.virtualmin.com/gpl/scripts/install.sh
sh ./install.sh
log:
Welcome to the Virtualmin GPL installer, version 1.1.0
WARNING:
The installation is quite stable and functional when run on a freshly
installed supported Operating System.
If you have existing websites, email users, or if you manually installed
Virtualmin via a Webmin ‘wbm’ module, you are likely to run into problems.
Please read the Virtualmin Administrators Guide before proceeding if
your system is not a freshly installed and supported OS.
This script is not intended to update your system! It should only be
used to perform your initial Virtualmin installation. If you have previously
run the Virtualmin installer, you can perform upgrades and updates from within
Virtualmin itself, or using your system’s package manager. Once Virtualmin is
installed, you never need to run this script again.
The systems currently supported by install.sh are:
CentOS and RHEL 5-6 on i386 and x86_64
Scientific Linux 6 on i386 and x86_64
Debian 6.0 and 7.0 on i386 and amd64
Ubuntu 8.04 LTS and 10.04 LTS, and 12.04 LTS on i386 and amd64
Amazon Linux 2012.03 on i386 and x86_64
FreeBSD 7.0 and 8 on i386 and amd64
If your OS is not listed above, this script will fail. More details
about the systems supported by the script can be found here:
http://www.virtualmin.com/os-support.html
Continue? (y/n) y
Checking for HTTP client…found /usr/bin/curl -s -O
Checking for perl…found /usr/bin/perl
Loading log4sh logging library…
INFO - Started installation log in /root/virtualmin-install.log
INFO - Checking for fully qualified hostname…
INFO - Hostname OK: fully qualified as server1.kaisatec.com
INFO - Installing serial number and license key into /etc/virtualmin-license
INFO - Loading OS selection library…
INFO - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - Loading OS list…
INFO - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = “UTF-8”,
LANG = “”
are supported and installed on your system.
perl: warning: Falling back to the standard locale (“C”).
INFO - Operating system name: CentOS Linux
INFO - Operating system version: 6
INFO - Configuring package manager for CentOS Linux 6…
INFO - Disabling SELinux during installation…
/usr/sbin/setenforce: SELinux is disabled
INFO - setenforce 0 failed: 1
INFO - Download of http://software.virtualmin.com/gpl/rhel/6/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
Running updatedb so locate works…this will take a little while.
Attempting to import various system RPM-GPG-KEY files…Errors may occur,
if you’ve already imported them. It is safe to ignore these errors.
/var/tmp/rpm-tmp.iAEKUM: line 30: [: Failed to set locale, defaulting to C 3: integer expression expected
/var/tmp/rpm-tmp.iAEKUM: line 33: [[: Failed to set locale, defaulting to C 3: syntax error in expression (error token is “to set locale, defaulting to C 3”)
INFO - Succeeded.
INFO - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate
…in progress, please wait…
-Failed to set locale, defaulting to C
|Warning: RPMDB altered outside of yum.
INFO - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-xml php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay mlocate: Succeeded.
INFO - Succeeded.
INFO - Installing Virtualmin and all related packages now using the command:
INFO - yum clean all
Loaded plugins: fastestmirror, security
Cleaning repos: base extras rpmforge updates virtualmin virtualmin-universal
Cleaning up Everything
Cleaning up list of fastest mirrors
INFO - yum -y -d 2 install virtualmin-base
INFO - yum -y -d 2 install virtualmin-base: Succeeded.
INFO - Checking for updates to Virtualmin-related packages…
INFO - Updating SpamAssassin rules…
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = “UTF-8”,
LANG = “”
INFO - Rule updates done
[root@server1 ~]# service httpd restart
Stopping httpd: [ OK ]
Starting httpd: [ OK ]
then I created 2 virtual servers.
a.com b.com
I checked /home/
there are 2 directory ‘a’,‘b’
when use ftp connect, it will lead to /home/a and /home/b
I uploaded file to /home/a/public_html and /home/b/public_html via ftp.
but in /etc/httpd/conf/httpd.conf it wrote
DocumentRoot “/var/www/html”
Options FollowSymLinks AllowOverride None
<Directory “/var/www/html”>
when I input a.com b.com to web browser and go
it only displayed
Index of /
[ICO] Name Last modified Size Description
it looks like I am led to /var/www/html rather than /home/a/public_html and /home/b/public_html
[root@server1 etc]# ls
ConsoleKit ftpusers named.rfc1912.zones redhat-release
DIR_COLORS ftpusers.rpmsave named.root.key resolv.conf
DIR_COLORS.256color gai.conf nanorc rndc.key
DIR_COLORS.lightbgcolor gcrypt networks rpc
GeoIP.conf gnupg nsswitch.conf rpm
GeoIP.conf.default group ntp rsyslog.conf
NetworkManager group- ntp.conf rsyslog.d
X11 grub.conf odbc.ini rwtab
abrt gshadow odbcinst.ini rwtab.d
acpi gshadow- openldap sasl2
adjtime gtk-2.0 opt scl
aliases hal pam.d scponly
aliases.db host.conf pango securetty
alsa hosts passwd security
alternatives hosts.allow passwd- selinux
anacrontab hosts.deny pcmcia services
apt httpd pear sestatus.conf
asound.conf init pear.conf setuptool.d
at.deny init.d php.d shadow
audisp inittab php.ini shadow-
audit inputrc php.ini-zend_optimizer.bak shells
awstats iproute2 php.ini.ctohome.com skel
bash_completion.d iscsi pinforc smart
bashrc issue pki smartd.conf
blkid issue.net plymouth smrsh
centos-release kdump-adv-conf pm snmp
chkconfig.d kdump.conf pm-utils-hd-apm-restore.conf sos.conf
clamd.conf krb5.conf polkit-1 ssh
cron.d ld.so.cache popt.d ssl
cron.daily ld.so.conf portreserve statetab
cron.deny ld.so.conf.d postfix statetab.d
cron.hourly lftp.conf ppp subversion
cron.monthly libaudit.conf prelink.cache sudo-ldap.conf
cron.weekly libreport prelink.conf sudo.conf
crontab libuser.conf prelink.conf.d sudoers
crypttab localtime printcap sudoers.d
csh.cshrc login.defs procmailrc sysconfig
csh.login logrotate.conf profile sysctl.conf
dbus-1 logrotate.d profile.d system-release
default lvm proftpd.conf system-release-cpe
depmod.d magic proftpd.conf.rpmnew terminfo
dhcp mail protocols udev
dovecot mail.rc quotagrpadmins updatedb.conf
dracut.conf mailcap quotatab usermin
dracut.conf.d mailman rc vimrc
environment makedev.d rc.d virc
ethers man.config rc.local virtualmin-license
event.d mime.types rc.sysinit warnquota.conf
exports mke2fs.conf rc0.d webalizer.conf
favicon.png modprobe.d rc1.d webmin
filesystems motd rc2.d wgetrc
fonts mtab rc3.d xdg
fprintd.conf my.cnf rc4.d xinetd.d
freshclam.conf named rc5.d yum
freshclam.conf.rpmnew named.conf rc6.d yum.conf
fstab named.iscdlv.key readahead.conf yum.repos.d
there is no directory ‘apache2’
of course, there is no directory ‘/etc/apache2/sites-available/’ neither
cd /etc/apache2
-bash: cd: /etc/apache2: No such file or directory
Uh-oh. Trying to “reinstall Virtualmin” by running the installer script again is… problematic. Not recommended for sure. The installer script is meant primarily to be used on a fresh OS.
So at this point, I guess it’d be better to reinstall the OS and try again. :slight_smile: Of course, Eric might have some further input on this, CentOS indeed isn’t my area of expertise. (Yes, I keep forgetting there are distros besides Debian/Ubuntu, which do things differently, like the httpd.conf bit. :slight_smile: )
I think the problem is
I used ensim before, when I added a new site, there was option for ‘add ip-based site’ or and ‘add named-base site’.
But in virtualmin , there is no such option.
how to make the created new vitual server for name-based?
Virtualmin uses name-based virtual hosts by default, when you have your server’s IP address configured as “shared IP”, which Virtualmin also does automatically by default.
Normally, you don’t have to do anything besides create the server, and Virtualmin takes care of creating a proper VirtualHost block.
Did you install Virtualmin on a fresh system, or over existing things?
it is not a pure os
I have installed something
I do not hope to re-install os
I will check if the problem can be fixed
If Apache isn’t configured to perform Name-based virtual hosting for your IP address, you may need to set that up.
That would normally be configured for you by default, when running the installer on a fresh system, but it’s possible that didn’t work properly in your case since it wasn’t a fresh system.
To do that, you’d just need to add a line like this to your httpd.conf:
NameVirtualHost x.x.x.x:80
Where “x.x.x.x” is your server’s IP address.
Also, note that there are some troubleshooting steps for the issue you’re seeing here in the section “the wrong website shows up”:
https://www.virtualmin.com/documentation/web/troubleshooting
I just purchased a vps server on linode with fresh os.
I will checked if the problem still existes
