Old installer [INFO] Banner
OS type and version Ubuntu 24.04 LTS arm64
Webmin version REQUIRED
Virtualmin version REQUIRED
Webserver version REQUIRED
When executing the install.sh script the old [INFO] banner is being displayed.
version is still 7.4.0 and there is no information about ARM processors on the supported list.
[INFO] Log will be written to: /root/virtualmin-install.log
  Welcome to the Virtualmin GPL installer, version 7.4.0
  This script must be run on a freshly installed supported OS. It does not
  perform updates or upgrades (use your system package manager) or license
  changes (use the "virtualmin change-license" command).
  The systems currently supported by the install script are:
    Red Hat Enterprise Linux and derivatives
      - RHEL 8 and 9 on x86_64
      - Alma and Rocky 8 and 9 on x86_64
      - CentOS 7 on x86_64
    Debian Linux and derivatives
      - Debian 10, 11 and 12 on i386 and amd64
      - Ubuntu 20.04 LTS, 22.04 LTS and 24.04 LTS on i386 and amd64
  If your OS/version/arch is not listed, installation will fail. More
  details about the systems supported by the script can be found here:
    https://www.virtualmin.com/os-support
  The selected package bundle is LAMP and the size of install is
  full. It will require up to 2 GB of disk space.
  Exit and re-run this script with --help flag to see available options.
 Continue? (y/n) y
That is not the current version of the install script. I recommend you follow our installation docs on our download page:
