you can not just create NS1.st3v3.co.uk and expect it to work. Nameservers need to be registered at your registrar. If they have no such service in their control panel, you may want to open a ticket with them and have them do it manually.
alternatively you can use the dyndns module in webmin and see if that brings about the changes you need.
At the moment the nameservers at the registrar do not exist on your machine and will not work at all.
Ok no problem (just trying to avoid spam and hacks) I will remove domains and IP’s later
the domain name i regestered was
i got it through 1and1 and i set up their dns redirect to go to my dyndns account name. which points to my static IP. (), I would have just used the static ip on 1and1 but it does not support ip’s just names.
I then needed a second dns server for 1and1 so decided to use ns1.
I created the Nameserver NS1. > and the A record for NS1.
when i try to ping the ns1.it comes back with unknown host
if i use infodns it says there is no A record for ns1.but there is.
