Not honouring Authentic Theme setting
Usermin version 2.400
Virtualmin version 7.40.0
Theme version 25.01
Nginx version 1.18.0
just done the Webmin/Virtualmin upgrade on my last VM.
Logged in as usual (and did the Authentic Theme reload as prompted)
for some reason it went to Webmin in the left panel (usually goes to Virtualmin as rarely have need to go in Webmin)
but somewhat surprised that the selected domain in the theme setting did not load as usual.
it loaded the first alphabetically listed domain :frowning:
ok, I only had to select the correct domain from the dropdown. but irritating when you just start doing other things when you assume nothing has changed.
The selected domain sticks unless you log out and log back in, or if you clear the browser’s cache. In that case, it will go to the default domain set in the theme settings.
Awesome, I missed this one while I was hibernating. :slight_smile:
yes that was where it was set though i have just gone back to check and found it back to ‘dashboard’. I guess reloading the theme must have reset :man_shrugging: which sort of makes sense - i must go back into other VMs and check them.
