Im using vm pro and when editing an html file with file manager I get a text file to edit rather than xinha which I was getting before, is there a setting I need to tweak? or has it been dropped? or what?
It seems the new Filemin manager that replaces the old deprecated Java one does not have a file code editor at all.
A WYSIWYG like TinyMCE would be welcome and also a code editor for HTML/PHP, and other common languages.
But to answer your question. No, there is none. You should probably add this as a feature request, as personally I also thing there should be at least a simple editor vs just giving users the option to download the file.
ok, thanks. I have no idea where to file a feature request, do you know? or anyone?
Here:
https://www.virtualmin.com/node/add/project-issue
You can also click on the top Issues button, its actually not just issues, you can also submit a feature request.
yes, thanks, done.
