j007w
June 3, 2021, 2:39pm
#1
Operating system: CentOS
**OS version:**7
I’m running Nginx and have PHP 5.6, 7.2 and 7.4 installed. Even though I have selected 7.4 PHP-fcgid to be the default for each domain and in Server Templates, in running processes I see that some domains are running 7.2. A few are even running 7.2 and 7.4 simultaneously.
What do I need to do so that all domains only run 7.4?
Thanks!
j007w
June 6, 2021, 1:43am
#2
Should I uninstall 5.6 and 7.2? I’ve been searching all over but haven’t found any articles regarding this issue. Does anyone have any suggestions? Thanks
Joe
June 6, 2021, 2:28am
#3
I’ve seen a couple of reports of this, but I can’t even imagine how it could happen.
Can you post the nginx config for this virtual host?
j007w
June 7, 2021, 1:52am
#4
Hi Joe.
Thanks so much for helping me. Here’s what the config for one of the domains that are running multiple PHP versions. Please let me know your thoughts.
server {
server_name domain.com www.domain.com;
listen 123.456.789.000;
root /home/domain/public_html;
index index.html index.htm index.php;
access_log /var/log/virtualmin/domain.com_access_log;
error_log /var/log/virtualmin/domain.com_error_log;
fastcgi_param GATEWAY_INTERFACE CGI/1.1;
fastcgi_param SERVER_SOFTWARE nginx;
fastcgi_param QUERY_STRING $query_string;
fastcgi_param REQUEST_METHOD $request_method;
fastcgi_param CONTENT_TYPE $content_type;
fastcgi_param CONTENT_LENGTH $content_length;
fastcgi_param SCRIPT_FILENAME /home/domain/public_html$fastcgi_script_name;
fastcgi_param SCRIPT_NAME $fastcgi_script_name;
fastcgi_param REQUEST_URI $request_uri;
fastcgi_param DOCUMENT_URI $document_uri;
fastcgi_param DOCUMENT_ROOT /home/domain/public_html;
fastcgi_param SERVER_PROTOCOL $server_protocol;
fastcgi_param REMOTE_ADDR $remote_addr;
fastcgi_param REMOTE_PORT $remote_port;
fastcgi_param SERVER_ADDR $server_addr;
fastcgi_param SERVER_PORT $server_port;
fastcgi_param SERVER_NAME $server_name;
fastcgi_param HTTPS $https;
client_max_body_size 200m;
set $skip_cache 0;
# CACHE SKIP RULES - START
# Do not cache POST requests - they should always go to PHP
if ($request_method = POST) {
set $skip_cache 1;
# Do not cache URLs with a query string - they should always go to PHP
if ($query_string != "") {
set $skip_cache 1;
# WooCommerce-specific cache skip rules
if ($request_uri ~* "/store.*|/cart.*|/my-account.*|/checkout.*|/addons.*|/shop.*") {
set $skip_cache 1;
set $skip_cache_reason WP_WooCommerce;
if ($cookie_woocommerce_items_in_cart) {
set $skip_cache 1;
if ($request_uri ~* ("/cart.*")) {
set $skip_cache 1;
# Don't cache URIs containing the following segments (admin panel, sitemaps, feeds, etc.)
if ($request_uri ~* "(/wp-admin/|/xmlrpc.php|/wp-(app|cron|login|register|mail).php|wp-.*.php|/feed/|index.php|wp-comments-popup.php|wp-links-opml.php|wp-locations.php|sitemap(_index)?.xml|[a-z0-9_-]+-sitemap([0-9]+)?.xml)") {
set $skip_cache 1;
# Don't use the cache for logged-in users or recent commenters
if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_no_cache|wordpress_logged_in") {
set $skip_cache 1;
# CACHE SKIP RULES - END
include /home/domain/public_html/hidemywpghost.conf;
location / {
# This is cool because no php is touched for static content.
# include the "?$args" part so non-default permalinks doesn't break when using query string
try_files $uri $uri/ /index.php?$args;
location ~ \.php$ {
try_files $uri =404;
fastcgi_pass unix:/var/php-nginx/158817213828777.sock/socket;
fastcgi_cache WORDPRESS;
fastcgi_cache_valid 200 60m;
fastcgi_cache_bypass $skip_cache;
fastcgi_no_cache $skip_cache;
fastcgi_split_path_info ^(.+?\.php)(/.*)$;
if (!-f $document_root$fastcgi_script_name) {
return 404;
listen 123.456.789.000:443 ssl;
ssl_certificate /home/domain/ssl.cert;
ssl_certificate_key /home/domain/ssl.key;
fastcgi_read_timeout 300;
j007w
June 10, 2021, 6:26pm
#5
Does anyone have an idea what’s happening? Thanks
system
closed
August 9, 2021, 6:26pm
#6
