Hi, i’ve been looking for a solution all over and cant find one,
i have installed virtualmin script installer fresh on centos 6.
And added nginx. All fine i have several servers setup on dual this one nginx only.
Now i know dual is not supported but there a ways around with some manualwork what really bothers me i cannot get the log’s tab to show up even when it’s only running on nginx,
I have checked permissions!
Logs name ie: containing the domain name first
i tried adding apache as usergroup
i just can’t get virtualmin to show nginx logs!!!
So am i missing something here? log format? just can’t understand!
Please help with this stupid issue
here’s a quick hack, edit virtual-server-lib-funcs.pl
(for me in debian in was in /usr/share/webmin/virtual-server )
(check your nginx log path is the same)
add this around line 11091 after the bandwidth button is added:
#nginx error log
push(@rv, { 'mod' => 'syslog',
'title' => 'Nginx Error Log',
'desc' => 'Nginx Error Log',
'page' => "save_log.cgi?view=1&file=/var/log/virtualmin/".$d->{'dom'}."_error_log",
'cat' => 'logs',
#nginx error log
now it wont show up straight away, as these links are cached, so you can wait of for a reload by going to line 10786:
local $crv = &get_links_cache($ckey, $v);
if ($crv) {
return @$crv;
change if($crv){ to if(0){
save, upload, refresh virtualmin, your new link’s should be visible, now undo this change and re-upload
