Good morning, I have a local server with virtualmin and the nextcloud script installed, but it runs very slow, do you recommend me to make some configurations for users to run faster when using the online application?
Server specs and connectivity aside:
On the nextcloud overview admin page it will give you performance advisories. Errors and stuff you should still configure.
Mostly caching. There are various different options.
You can also tweak php-fpm according to your system.
https://spot13.com/pmcalculator/
All of this is not really related to virtualmin.
