I’m in the process of migrating to Amazon EC2. I have backed up my sites from my previous VirtualMin and installed them on the new EC2 server.
However, none of my sites are visible externally.
When I ping a site, it returns the internal address for the server and not the public facing IP.
Attached is a screenshot of the network .
Here are the results of my re-check config
Your system has 3.45 GB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Postfix can support per-domain outgoing IP addresses, but is not currently configured to do so. This can be setup in the Postfix Mailserver module.
Apache is installed.
The following PHP versions are available : 5.4.16 (/bin/php-cgi)
Apache is configured to host SSL websites.
MySQL is installed and running.
ProFTPd is installed.
Logrotate is installed.
SpamAssassin and Procmail are installed and configured for use.
ClamAV is installed and assumed to be running.
Plugin Protected web directories is installed OK.
Using network interface eth0 for virtual IPs.
Default IPv4 address for virtual servers is 172.30.0.212.
Both user and group quotas are enabled for home and email directories.
All commands needed to create and restore backups are installed.
The selected package management and update systems are installed OK.
… your system is ready for use by Virtualmin.
