| SYSTEM INFORMATION |
| OS type and version |
Ubuntu Linux 20.04.6 |
| Webmin version |
2.021 |
| Virtualmin version |
7.7 Pro |
| Related packages |
SUGGESTED |
hello can any one help me with my issue im get this problem when i check my dns server on mxtoolbox it keeps coming up with the following two errors
my domain name and dns is with namecheap too
ID10T
2
Are you hosting your dns or is it with your registrar?
You need a A record first off.
no my dns is with namecheap
All those records need to be on namecheap, virtualmin is not handling the DNS, disable vitualmin dns.
ok how do i solve the problem
im having problems setting up the mailserver to
thats the dns issue.
follow these instructions,
ok thank you for your help
notice how they add the host just www for www.yourdomain.com
yes i have noticed that do i do the same
yep. not ns1 and ns2 as your not running the nameserver.
www mail & smtp the main ones
oh right i understand so do i remove ns1 and ns2 then
only the one point to Virtualmin, you should have ns pointing to namecheap nameserver.
dns1.namecheaphosting.com, dns2.namecheaphosting.com
do i add them to virtualmin or what
this is what shows up in my dns records
no virtualmin is not your nameservers, namecheap is.
