Hello new user to VirtualMin here.
I have a ubuntu VPS that I am working on setting up 2 different domain/websites on. Both are intended to be eCommerce websites. Let’s call them siteA.com, and siteB.net.
First (possible) issue is when I install virtualmin from the auto install script, it asks for a host name, I’m not sure what to put in this because my host is an IP, and that doesn’t seem to work. So I have been using a temporary domain that is unrelated just to get virtualmin to install.
Second issue is once I am setup, when I try to make separate virtual servers for siteA.com and siteB.net, there seems to be no way to access them? The URL links on virtualmin are broken and say error 403 forbidden.
Also, I linked the actual domain name “siteA.com” to my IP address, and it works fine when first installing virtualmin. But once I make a virtual server for siteA.com, the domain stops working? I can still access the site through the IP, but the domain simply stops working and I’m not sure why.
Basically I need to get both sites working independent and linked to the domains, so I can install separate eCommerce solutions on each one, and access to them through the domains siteA.com and siteB.net in my browser.
And I want the actual Virtualmin to only be accessed through the IP, and not a domain name, if possible. Not sure how to do that since the installer is asking me for a host name…
Any ideas on why this is being so problematic? Been trying to figure it out all day…
The hostname that the installer asks for would probably be that which you ultimately wish to use, i.e. “siteA.com” and “siteB.com”. It’s a good idea to register an “administrative domain”, like “myhostingdomain.com”, and give your server a hostname “myserver.myhostingdomain.com” under it. Use that domain for admin purposes like accessing Virtualmin or hosting DNS zones as “ns1.myhostingdomain.com”.
The 403 forbidden error probably means that you’re trying to access an empty public_html directory.
Make sure not to put the hostname you use for your server under Virtualmin control, that usually leads to problems.
You COULD make Virtualmin only accessible through the IP address, but you should have a good reason for that, since it makes things more complicated.
Okay so if I made ns1.mydomain.com, would I set that as the virtualmin host name?
Also, why is my domain breaking once make virtual servers with Virtualmin? For example, if my domain is 12.34.56.78, I can access it fine, adn then accessing 12.34.56.78:10000 works for administration.
Then I can try accessing through my domain - for example siteA. siteA.com works, and siteA.com:10000 works for administration.
Once I add a subdomain in virtualmin… I can still access through 12.34.56.78:10000. But siteA.com stops working, and siteA.com:10000 stops working?
Shouldn’t it still at least be linked to admin page since my domain siteA.com is pointing to 12.34.56.78? I have no idea why siteA.com:10000 stops working?
Also, since you mentioned 403 probably means trying to access an empty directory… but I’m wondering, lets say my domain is again siteA.com, and I create a virtual named “myvirtual”… what is the URL I would use to access myvirtual?
