i am trying to follow instructions on the link below, but have no idea how to do it using Webmin.
https://www.massmailsoftware.com/support/verifier-use-web-script.php
Can someone walk me through the instructions?
thanks
thanks
sorry, I misread the instructions, I thought you downloaded, but it look slike you have to tell them your location
Brian
Uhm, its even stated in the link.
You need to upload the script / files into the web folder of the user (where you want it to be checked).
For that you need a FTP access. You can create that in virtual min at “Edit Users”. When you clicked that, you can click “Add a website ftp access user”.
That being done, you can use your FTP program to upload the files and then use your browser to browse the script.
