hello
i set up a domain (domain.com) with virtualmin, but i cannot send email with mail() (not using any smtp), and i cannot receive email sent to for example contact@domain.com.
my domain is registered at another host company OVH, so the primary and secondary DNS server are at htis webhosting company 's. The dedicated server is at Onlline.
What should i do to make it work?
the website is working because in the zone configuration the A record point to the ip of my dedicated server at Online.
What are the tweaking at OVH and Online to make mail() and the reception of email working?
What you may want to do is look in your email logs to see what’s happening with those emails… those are located in /var/log/mail.lor or /var/log/maillog.
Also, if your DNS is hosted elsewhere, be sure to disable the “DNS Domain” feature on your Virtual Server. That can be tweaked by going into Edit Virtual Server -> Enabled Features.
Hello this is a fresh excerpt of var/log/mail.log : i hope it contains necessary information.
What i think is there is a smtp problem isn’t it?
Aug 23 15:19:37 sd-23481 postfix/error[2744]: DADCC8116E: to=thomasannuaires@yopmail.com, relay=none, delay=935, delays=933/1/0/0.09, dsn=4.3.0, status=deferred (unknown mail transport error)
Aug 23 15:24:36 sd-23481 postfix/qmgr[18324]: DFA3381163: from=gammaseotools@sd-23481.localdomain, size=717, nrcpt=1 (queue active)
Aug 23 15:24:36 sd-23481 postfix/qmgr[18324]: A71DA8115D: from=gammaseotools@sd-23481.localdomain, size=708, nrcpt=1 (queue active)
Aug 23 15:24:36 sd-23481 postfix/smtp[3181]: fatal: unknown service: smtp/tcp
Aug 23 15:24:36 sd-23481 postfix/smtp[3182]: fatal: unknown service: smtp/tcp
Aug 23 15:24:37 sd-23481 postfix/qmgr[18324]: warning: private/smtp socket: malformed response
Aug 23 15:24:37 sd-23481 postfix/qmgr[18324]: warning: transport smtp failure – see a previous warning/fatal/panic logfile record for the problem description
Aug 23 15:24:37 sd-23481 postfix/master[18322]: warning: process /usr/lib/postfix/smtp pid 3181 exit status 1
Aug 23 15:24:37 sd-23481 postfix/master[18322]: warning: /usr/lib/postfix/smtp: bad command startup – throttling
Aug 23 15:24:37 sd-23481 postfix/master[18322]: warning: process /usr/lib/postfix/smtp pid 3182 exit status 1
Aug 23 15:24:37 sd-23481 postfix/error[3183]: DFA3381163: to=patrimoine62@gmail.com, relay=none, delay=42597, delays=42596/1/0/0.1, dsn=4.3.0, status=deferred (unknown mail transport error)
Aug 23 15:24:37 sd-23481 postfix/error[3184]: A71DA8115D: to=zylnia@free.fr, relay=none, delay=55077, delays=55076/1/0/0.13, dsn=4.3.0, status=deferred (unknown mail transport error)
Ah, it looks like the Postfix “smtp” service is failing.
My suggestion would be to restart Postfix with “/etc/init.d/postfix restart”, and look at the logs immediately after that happens, to see what errors show up then.
Also, can you attach your /etc/postfix/master.cf file? It sounds like there may be a problem with something in it.
hi Eric,
i tried to send and email and here is the return error i have. I think something is wrong with the MX record?
Please notice that Free.fr is the sister company of online.net (where my dedicated server is rent)
why does it say unknown? I still cannot use the mail() function (without specifying the smtp server), and in roundcube. but i can send an email to myself both with mail() and roundcube.
Sujet:
test
De :
zylnia
Date :
Tue, 23 Aug 2011 22:10:50 +0200
Pour :
contact@gammaseotools.com
Received:
from [192.168.0.90] (unknown [88.176.211.184]) by smtp2-g21.free.fr (Postfix) with ESMTP id 62B624B0156 for ; Tue, 23 Aug 2011 22:10:31 +0200 (CEST)
ID du message :
<4E54094A.2050808@free.fr>
Agent utilisateur:
Mozilla/5.0 (Windows; U; Windows NT 6.1; fr; rv:1.9.2.20) Gecko/20110804 Thunderbird/3.1.12
Version de MIME:
1.0
Content-Type:
text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding:
7bit
Hi Eric, this IP is not my server, mine is 88.191.129.202.
I can now send email with mail(), and free.fr has lifted the ban on my IP. Why can i send only to myself?
I first hosted gammaseotools.com on my dedicated server at OVH, but now have moved to the online.net Dedibox. So the zone file still exists on my Dedibox, should i delete gammaseotools.com from the OVH server (Zone file and virtual server?
for your information i made a screenshot of the configuration at OVH (the registrar)
If you have a DNS zone file for a domain, but you don’t intend on hosting DNS for that domain – I would suggest removing that DNS zone… that could certainly cause problems.
I’d also suggest attempting to send an email to a different account – perhaps a Gmail account – and then review the logs to see what happens to that email. If it works going to a Gmail account, then it may be related to just that one domain that you once hosted.
here is the log after sending a mail to gmail, seems all good.
Aug 24 20:32:33 sd-23481 postfix/qmgr[4771]: 1691981162: from=gammaseotools@sd-23481.localdomain, size=667, nrcpt=1 (queue active)
Aug 24 20:32:33 sd-23481 postfix/smtp[5702]: 1691981162: to=gammatools@gmail.com, relay=gmail-smtp-in.l.google.com[74.125.79.27]:25, delay=0.57, delays=0.21/0.02/0.13/0.21, dsn=2.0.0, status=sent (250 2.0.0 OK 1314210753 t1si1448456eef.116)
Aug 24 20:32:33 sd-23481 postfix/qmgr[4771]: 1691981162: removed
Since gammaseotools.com dns are set to ns17.ovh.net (primary) and dns17.ovh.net, there is a zone file at ovh for this domain, i removed the zone file on my Dedibox in Bind is it ok?
Looks like that email to Gmail went through just fine.
As far as your other domain goes – normally, you can remove DNS settings by just going into Edit Virtual Server -> Enabled Features, and disable the “BIND DNS Domain” feature.
If you don’t have that domain setup in Virtualmin, then yeah, you can simply remove the BIND zone file (and the related configuration).
