I’ve got a wordpress install where the databases use the vitrtualmin login password. As a security measure I’d like to change the virtualmin login pasword without changing the password access needed by wordpress - I don’t want wp to stop working. What’s the best way to do this?
create new user with new password inside phpmyadmin
click on database and grant all privileges to that user for that database - you may log out from root in phpmyadmin and log as that user to check if you can see database as that new user
edit your wp-config and change user details with database details like password and user name
check your wp site that is working by visiting your blog install
log into webmin/virtualmin - go to your domain where wp is installed and disassociate the database with current domain user
check your wp site again (it should be still up and running just fine) - you are done.
