Hint: If you can’t get rid of it, for now it should help too to just disable its autostart. You can do that with the Webmin module “System -> Bootup and Shutdown”.
Ok ive done that so is this all set up and working right now ? lol
Big thanks also
This is the log after bind reboot and powerdns gone
Nov 11 19:21:01 ks312361 /USR/SBIN/CRON[14872]: (root) CMD (/usr/local/rtm/bin/rtm 24 > /dev/null 2> /dev/null)
Nov 11 19:21:13 ks312361 named[3869]: shutting down
Nov 11 19:21:13 ks312361 named[3869]: stopping command channel on 127.0.0.1#953
Nov 11 19:21:13 ks312361 named[3869]: stopping command channel on ::1#953
Nov 11 19:21:13 ks312361 named[3869]: no longer listening on 127.0.0.1#53
Nov 11 19:21:13 ks312361 named[3869]: no longer listening on 188.165.217.101#53
Nov 11 19:21:13 ks312361 named[3869]: no longer listening on ::1#53
Nov 11 19:21:13 ks312361 named[3869]: exiting
Nov 11 19:21:13 ks312361 named[14934]: starting BIND 9.6-ESV-R1 -c /etc/bind/named.conf
Nov 11 19:21:13 ks312361 named[14934]: built with '--prefix=/usr' '--build=x86_64-linux-gnu' '--host=x86_64-linux-gnu' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--sysconfdir=/etc/bind' '--localstatedir=/var/run/bind' '--enable-threads' '--enable-largefile' '--with-libtool' '--enable-shared' '--enable-static' '--with-openssl=/usr' '--with-gssapi=/usr' '--with-gnu-ld' '--with-dlz-postgres=no' '--with-dlz-mysql=no' '--with-dlz-bdb=yes' '--with-dlz-filesystem=yes' '--with-dlz-ldap=yes' '--with-dlz-stub=yes' '--enable-ipv6' 'build_alias=x86_64-linux-gnu' 'host_alias=x86_64-linux-gnu' 'CFLAGS=-fno-strict-aliasing -DDIG_SIGCHASE -DNS_RUN_PID_DIR=0 -O2' 'LDFLAGS=' 'CPPFLAGS=' 'CXXFLAGS=-g -O2' 'FFLAGS=-g -O2'
Nov 11 19:21:13 ks312361 named[14934]: adjusted limit on open files from 1024 to 1048576
Nov 11 19:21:13 ks312361 named[14934]: found 8 CPUs, using 8 worker threads
Nov 11 19:21:13 ks312361 named[14934]: using up to 4096 sockets
Nov 11 19:21:13 ks312361 named[14934]: loading configuration from '/etc/bind/named.conf'
Nov 11 19:21:13 ks312361 named[14934]: using default UDP/IPv4 port range: [1024, 65535]
Nov 11 19:21:13 ks312361 named[14934]: using default UDP/IPv6 port range: [1024, 65535]
Nov 11 19:21:13 ks312361 named[14934]: listening on IPv4 interface lo, 127.0.0.1#53
Nov 11 19:21:13 ks312361 named[14934]: listening on IPv4 interface eth0, 188.165.217.101#53
Nov 11 19:21:13 ks312361 named[14934]: listening on IPv6 interface lo, ::1#53
Nov 11 19:21:13 ks312361 named[14934]: automatic empty zone: 254.169.IN-ADDR.ARPA
Nov 11 19:21:13 ks312361 named[14934]: automatic empty zone: 2.0.192.IN-ADDR.ARPA
Nov 11 19:21:13 ks312361 named[14934]: automatic empty zone: 255.255.255.255.IN-ADDR.ARPA
Nov 11 19:21:13 ks312361 named[14934]: automatic empty zone: 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.IP6.ARPA
Nov 11 19:21:13 ks312361 named[14934]: automatic empty zone: 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.IP6.ARPA
Nov 11 19:21:13 ks312361 named[14934]: automatic empty zone: D.F.IP6.ARPA
Nov 11 19:21:13 ks312361 named[14934]: automatic empty zone: 8.E.F.IP6.ARPA
Nov 11 19:21:13 ks312361 named[14934]: automatic empty zone: 9.E.F.IP6.ARPA
Nov 11 19:21:13 ks312361 named[14934]: automatic empty zone: A.E.F.IP6.ARPA
Nov 11 19:21:13 ks312361 named[14934]: automatic empty zone: B.E.F.IP6.ARPA
Nov 11 19:21:13 ks312361 named[14934]: command channel listening on 127.0.0.1#953
Nov 11 19:21:13 ks312361 named[14934]: command channel listening on ::1#953
Nov 11 19:21:13 ks312361 named[14934]: zone 0.in-addr.arpa/IN: loaded serial 1
Nov 11 19:21:13 ks312361 named[14934]: zone 127.in-addr.arpa/IN: loaded serial 1
Nov 11 19:21:13 ks312361 named[14934]: zone 255.in-addr.arpa/IN: loaded serial 1
Nov 11 19:21:13 ks312361 named[14934]: zone babylon5rpg.com/IN: loaded serial 1289353370
Nov 11 19:21:13 ks312361 named[14934]: zone mana4x2rpg.com/IN: loaded serial 1289491524
Nov 11 19:21:13 ks312361 named[14934]: zone myanimeisland.com/IN: loaded serial 1289365276
Nov 11 19:21:13 ks312361 named[14934]: zone rpg-central.com/IN: loaded serial 1289352156
Nov 11 19:21:13 ks312361 named[14934]: zone stargatecommandrpg.com/IN: loaded serial 1289357904
Nov 11 19:21:13 ks312361 named[14934]: zone localhost/IN: loaded serial 2
Nov 11 19:21:13 ks312361 named[14934]: /var/lib/bind/vodkaholic.co.uk.hosts:20: file does not end with newline
Nov 11 19:21:13 ks312361 named[14934]: zone vodkaholic.co.uk/IN: loaded serial 1289399469
Nov 11 19:21:13 ks312361 named[14934]: running
Resolution works okay now, yet IntoDNS still reports some errors/warnings. Some of them are related to the fact that you have two nameservers listed under the same IP. That is not recommended nor useful… You should have a secondary nameserver for your zone that is for many TLDs even required to be in a different /24 network.
secondary nameserver hmm i only have one server
Does your hoster maybe offer secondary nameserver services? Often they do that, for customers who wish to operate the primary, but have only one server/network.
Ok thanks alot Locutus
You’re welcome!
