Now my mate has stoped running this nameserver
So i have no idea what i can do now
My Main Domain is myanimeisland.com is there a way i can add ns1.myanimeisland.com and ns2 and all will work?
Sorry its bloody hard to type and explain this problem
ive got 123-reg to register the name servers ns1.myanimeisland.com and ns1 to my servers IP
I did a test and added ns1.myanimeisland.com to vodkaholic.co.uk but it just gives me “Oops! Google Chrome could not find vodkaholic.co.uk” when i look at the site
Hope you can understand some of this post
Thanks alot
Mike
So it sounds like you’re saying you need a place to host a set of nameservers for the domains you’re hosting.
Yeah, you can do that on your own server without a problem – though, just remember that you can’t just make up the names “ns1.myanimeisland.com” and “ns2.myanimeisland.com”.
In order to use those, you need to do two things:
In Virtualmin, go to Services -> DNS Domain, and add an “Address” record for each of those
Go to your domain name registrar, and you’ll need to register each as nameservers with your registrar. Once they’re registered as nameservers, you’ll be able to add them as the nameservers for your domain “vodkaholic.co.uk”.
After that, your server should start answering DNS lookup requests for that domain (and any other domain you add those nameservers to).
It sounds like it’s not seeing the ns1 and ns2 Address records added to your servers DNS yet. Make sure you add those first. If you did add them, you have to hit “Apply Zone” afterwards to make them take effect.
According to it, it’s not seeing Address records for your nameservers.
Remember that for this to work, the DNS for myanimeisland.com would need to be hosted on your server as well… it doesn’t appear to be, as the nameservers for that domain point to ns1.hidnet.org.uk and ns2.hidnet.org.uk.
So when those lookups are taking place, they aren’t querying your server, they’re querying hidnet.org.uk.
Am using ns1 and 2 .vodkaholic.co.uk now
Ive added this in the nameservers for the domain also ive asked my domain host to register these as nameservers to the following IP 188.165.217.101
I still see nothing on vodkaholic.co.uk but am guessing its not registered the nameservers yet
The NS and A entries from the registrar are set correctly and propagated now. Your sever 188.165.217.101 though says SERVFAIL when querying *.vodkaholic.co.uk.
Seems the BIND on that host is not yet correctly configured to serve that domain. It might help to use the Webmin BIND module’s functions Check BIND Config globally, and Check records for the zone, to see any errors.
Okay, then click “Check BIND Config” in the main screen, it’s the second icon to the right on the bottow row. The error might be in BIND’s main config file itself.
If there’s no error reported there as well, try restarting BIND and then check /var/log/syslog or other logs there where BIND possibly records what it has to say.
No errors were found in the BIND configuration file /etc/bind/named.conf or referenced zone files.
This is the log after a restart
Nov 11 01:33:11 ks312361 named[8595]: shutting down
Nov 11 01:33:11 ks312361 named[8595]: stopping command channel on 127.0.0.1#953
Nov 11 01:33:11 ks312361 named[8595]: stopping command channel on ::1#953
Nov 11 01:33:11 ks312361 named[8595]: no longer listening on ::1#53
Nov 11 01:33:11 ks312361 named[8595]: exiting
Nov 11 01:33:11 ks312361 named[8788]: starting BIND 9.6-ESV-R1 -c /etc/bind/named.conf
Nov 11 01:33:11 ks312361 named[8788]: built with '--prefix=/usr' '--build=x86_64-linux-gnu' '--host=x86_64-linux-gnu' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--sysconfdir=/etc/bind' '--localstatedir=/var/run/bind' '--enable-threads' '--enable-largefile' '--with-libtool' '--enable-shared' '--enable-static' '--with-openssl=/usr' '--with-gssapi=/usr' '--with-gnu-ld' '--with-dlz-postgres=no' '--with-dlz-mysql=no' '--with-dlz-bdb=yes' '--with-dlz-filesystem=yes' '--with-dlz-ldap=yes' '--with-dlz-stub=yes' '--enable-ipv6' 'build_alias=x86_64-linux-gnu' 'host_alias=x86_64-linux-gnu' 'CFLAGS=-fno-strict-aliasing -DDIG_SIGCHASE -DNS_RUN_PID_DIR=0 -O2' 'LDFLAGS=' 'CPPFLAGS=' 'CXXFLAGS=-g -O2' 'FFLAGS=-g -O2'
Nov 11 01:33:11 ks312361 named[8788]: adjusted limit on open files from 1024 to 1048576
Nov 11 01:33:11 ks312361 named[8788]: found 8 CPUs, using 8 worker threads
Nov 11 01:33:11 ks312361 named[8788]: using up to 4096 sockets
Nov 11 01:33:11 ks312361 named[8788]: loading configuration from '/etc/bind/named.conf'
Nov 11 01:33:11 ks312361 named[8788]: using default UDP/IPv4 port range: [1024, 65535]
Nov 11 01:33:11 ks312361 named[8788]: using default UDP/IPv6 port range: [1024, 65535]
Nov 11 01:33:11 ks312361 named[8788]: listening on IPv4 interface lo, 127.0.0.1#53
Nov 11 01:33:11 ks312361 named[8788]: could not listen on UDP socket: address in use
Nov 11 01:33:11 ks312361 named[8788]: creating IPv4 interface lo failed; interface ignored
Nov 11 01:33:11 ks312361 named[8788]: listening on IPv6 interface lo, ::1#53
Nov 11 01:33:11 ks312361 named[8788]: automatic empty zone: 254.169.IN-ADDR.ARPA
Nov 11 01:33:11 ks312361 named[8788]: automatic empty zone: 2.0.192.IN-ADDR.ARPA
Nov 11 01:33:11 ks312361 named[8788]: automatic empty zone: 255.255.255.255.IN-ADDR.ARPA
Nov 11 01:33:11 ks312361 named[8788]: automatic empty zone: 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.IP6.ARPA
Nov 11 01:33:11 ks312361 named[8788]: automatic empty zone: 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.IP6.ARPA
Nov 11 01:33:11 ks312361 named[8788]: automatic empty zone: D.F.IP6.ARPA
Nov 11 01:33:11 ks312361 named[8788]: automatic empty zone: 8.E.F.IP6.ARPA
Nov 11 01:33:11 ks312361 named[8788]: automatic empty zone: 9.E.F.IP6.ARPA
Nov 11 01:33:11 ks312361 named[8788]: automatic empty zone: A.E.F.IP6.ARPA
Nov 11 01:33:11 ks312361 named[8788]: automatic empty zone: B.E.F.IP6.ARPA
Nov 11 01:33:11 ks312361 named[8788]: command channel listening on 127.0.0.1#953
Nov 11 01:33:11 ks312361 named[8788]: command channel listening on ::1#953
Nov 11 01:33:11 ks312361 named[8788]: additionally listening on IPv4 interface lo, 127.0.0.1#53
Nov 11 01:33:11 ks312361 named[8788]: zone 0.in-addr.arpa/IN: loaded serial 1
Nov 11 01:33:11 ks312361 named[8788]: zone 127.in-addr.arpa/IN: loaded serial 1
Nov 11 01:33:11 ks312361 named[8788]: zone 255.in-addr.arpa/IN: loaded serial 1
Nov 11 01:33:11 ks312361 named[8788]: zone babylon5rpg.com/IN: loaded serial 1289353370
Nov 11 01:33:11 ks312361 named[8788]: zone myanimeisland.com/IN: loaded serial 1289365276
Nov 11 01:33:11 ks312361 named[8788]: zone rpg-central.com/IN: loaded serial 1289352156
Nov 11 01:33:11 ks312361 named[8788]: zone stargatecommandrpg.com/IN: loaded serial 1289357904
Nov 11 01:33:11 ks312361 named[8788]: zone localhost/IN: loaded serial 2
Nov 11 01:33:11 ks312361 named[8788]: zone vodkaholic.co.uk/IN: loaded serial 1289399469
Nov 11 01:33:11 ks312361 named[8788]: running
Nov 11 01:33:47 ks312361 pdns[20553]: Not authoritative for 'vodkaholic.co.uk', sending servfail to 92.114.98.140 (recursion was desired)
Nov 11 01:33:47 ks312361 pdns[20553]: Not authoritative for 'adobe.com', sending servfail to 92.114.98.140 (recursion was desired)
Nov 11 01:33:48 ks312361 pdns[20553]: Not authoritative for 'vodkaholic.co.uk', sending servfail to 209.85.228.84
Nov 11 01:33:54 ks312361 kernel: IPv6 addrconf: prefix with wrong length 56
First thing I see is an error about “could not listen on UDP socket, address in use” for the localhost. Odd thing, since it seems to be reacting to queries (at least on the eth) later. Might want to check, after shutting BIND down, if any other processes are listening on 53 (netstat -lupn).
Then, the configured zones seemed to have loaded fine, but queries were rejected with not authoritative for.... It’s possible there’s something wrong with the respective zone.
Can you please post the contents of /etc/bind/named.conf.local?
$ttl 38400
@ IN SOA ks*******.kimsufi.com. root.ks*********.kimsufi.com. (
1289399469
10800
3600
604800
38400 )
@ IN NS ks***********.kimsufi.com.
vodkaholic.co.uk. IN A 188.165.217.101
www.vodkaholic.co.uk. IN A 188.165.217.101
ftp.vodkaholic.co.uk. IN A 188.165.217.101
m.vodkaholic.co.uk. IN A 188.165.217.101
localhost.vodkaholic.co.uk. IN A 127.0.0.1
webmail.vodkaholic.co.uk. IN A 188.165.217.101
admin.vodkaholic.co.uk. IN A 188.165.217.101
vodkaholic.co.uk. IN MX 5 mail.vodkaholic.co.uk.
vodkaholic.co.uk. IN TXT "v=spf1 a mx a:vodkaholic.co.uk ip4:188.165.217.101 ?all"
ns1.vodkaholic.co.uk. IN A 188.165.217.101
ns2.vodkaholic.co.uk. IN A 188.165.217.101
Ive stared out my server name *****
Thanks again for the help
Okay, I see a problem there. What is “kimsufi.com”?
The NS entries at the NIC say that ns1.vodkaholic.co.uk., as in your server, is the authoritative nameserver for that domain, but in your zone file, you delegate the SOA and the NS to some system at a domain (kimsufi.com) which is not known to BIND. That is bound to confuse it.
The entries at the NIC must match what your zone file says for SOA and NS.
